    [Plugin] Extrude Edges by Face
    38 Posts 10 Posters 56.0k Views 10 Watching
      There are two tools EEbyFace and EEbyRailsByFace - you are jumbling the threads. πŸ˜•
      EEbyFace - you pre-pick a Face and a path of Edges and run the tool there are no prompts to pick curves etc
      EEbyRailsbyFaces
      Pre-pick the ProfileFace
      • you run the tool
        Pick the profiles as with EEbyRails...
      BUT it shouldn't dump out like that.
      I have tried to replicate this and got it too...
      I have a fix - publishing it soonest... πŸ˜’
        chrisjk
        TIG,
        True, I was jumbling the threads, I got confused here :-
        Face - Faces..
        and went on to see which of the plugins was actually giving me colours and got hung up on EEBRF. A different naming scheme would make it easier for us mortals! After all, EEBRBF extrudes a selected face along chosen edges, so something like "ExtrudeaFacebyRails" could help differentiate it better.
          I puzzled long about the names πŸ˜’
          I have a fix for that glitch but it's made another - offsetting the colored lines !
          I'll fix it tomorrow... πŸ’­ ➑
            about a quarter circle
            there is a divergence: I understant that is perpendicular to the last segment,
            but it is annoying for make a perfect quarter volume! ❓
              EEbyFace is a kind of 'FollowMe' and you will get un-square ends - use EEbyLathe to be perfect solid by revolution - simply select the face+edges and an axis centered on the arcs cpt... πŸ˜•
                magnato
                Is there a plugin that can delete all the faces in a structure, leaving it with only the edges? I would like to use the nice Extrude Edges by Face plugin to create a typical steel-like structure.
                Magnar
                I would like to make a structure with steel beams
                  To add/remove things to/from a selection there are several tools [e.g. see thomthom's selection_toys script]...
                  Here's a one liner that takes a selection [it assumes faces and edges are selected, and leaves only faces in the selection - hit delete key to erase faces...]
                  m=Sketchup.active_model;s=m.selection;sa=s.to_a;s.clear;sa.each{|e|s.add(e)if e.class==Sketchup;;Face}
                  Paste it into the Ruby Console and hit return...
                  To make a function wrap it in a 'def' thus:
                  def isolatefaces()
                    m = Sketchup.active_model
                    s = m.selection
                    sa = s.to_a
                    s.clear
                    sa.each{|e|
                      s.add(e) if e.class == Sketchup;;Face
                  end#def
                  ans save it in a plain text file called isolatefaces.rb in the ../Plugins/ folder.
                  To run it first select somethings, including faces, and type isolatefaces in the Ruby Console - out of the original selection just the faces are now selected - to erase them press the delete key...
                  πŸ€“
                    magnato
                    It worked! Very Cool!
                    I have find a symbol for this so I remember it when I need this function again !
                    Magnar
                    • Z Offline
                      zainulx3
                      Hi, i've been searching the link to download these extrude plugin(each of the features, faces, edges) but I can't find any.
                      Can you guys give the link beside this link
                      http://sketchucation.com/pluginstore?pln=ExtrudeTools
                      Thanks guys πŸ˜„
                      • cottyC Offline
                        cotty
                        What's wrong with this link?
                        my SketchUp gallery
                          That link [ http://sketchucation.com/pluginstore?pln=ExtrudeTools ] lets you Download the RBZ of all of the tools - click the RED button.
                          If you have the latest available update for v8 [>=M2] then you can AutoInstall the RBZ contents from the Preferences > Extensions > Install... button [provided you have FULL permissions to the Plugins folder - see this for advice too http://sketchucation.com/resources/tutorials/36-intermediate/811-setting-security-permissions-in-sketchup ]
                            DoyleZZ
                            Hi TIG,I like this plugin so much.But it can not work in SU2017 when i use Extrude Edges by Face
                              Several of the my "EEby" tools were unexpectedly broken by the way v2017 handles its entities' IDs when exploding a temporary group etc.
                              I have managed to fix almost all of the wayward code [keeping backward compatibility], however there are a few minor issues outstanding and the beta-testing to complete - I have been out of the loop for a week or two with family matters, but I hope to get back onto fixing these tools asap...
                              • 2 / 2
