    [Plugin] Component Dropper
    49 Posts 21 Posters 57.5k Views 21 Watching
    • U
      unclex
      use it.... for what ?????
        No chance to see Component Dropper multiple?
        That will be very cool! ☀
        1. Make a selection containing groups and components in a certain order (or automatically randomly with a general selection). (Doesn't matter if it contains more, it'll be ignored.)
        2. Activate the tool
        3. Pick another group**"s"** or component**"s"** instance in a certain order (or automatically randomly with a general selection) to replace your selection.
        • thomthomT
          in a certain order
          In which order?
            certain order
            In the order of the one by one clic selection
            Ps about the plug itself first post
            Does it possible to keep the original size of the component and not an adapted size?
            ( a simple past replace in place)
            • thomthomT
              No. But I've wanted this myself. So added to todo list.
              • EdsonE
                Edson
                Comp Dropper never got renamed to Comp Swopper, right?
                http://www.mahfuz.arq.br
                • EdsonE
                  Edson
                  thomas,
                  correct me if I am wrong. the way this plugin improves on the regular method (choosing a number of components in the model and replacing by another by right-clicking on this 2nd one in the components dialog and choosing "replace selected") is because it can also perform the same act on groups whereas the native method works only on components.
                  • thomthomT
                    It also tries to preserve the component instance's size.
                    • V
                      victor hugo
                      Is there something like the dropgc but to be undropped?
                      reason for this is when I work on placing light fixtures on a reflected ceiling, I will have those placed on the floor plan then "undrop" so they will attach to the ceiling?
                      is there something like it out there to do this?.
                      Thanks.
                        I have made in the past a sort of Undrop
                        Not sure it's that you want ?
                        You have also Eclate Deplace By Cplassay and me 😉
                        But if your lights are not Group or component that will be impossible!
                        • V
                          victor hugo
                          It is just the opposite of the DropGC...select compoment then undrop so instead of going down it will go up and hit the ceiling.
                          I have those as component/group.
                          I'll look at your links and see if it work for me.
                          Thanks for replying.
                          • Y
                            Yucon
                            Hi Tom,
                            I am trying to use your plugin and it almost works great but the boxes are jumping away from the original position. Is that a problem for sketchup 2013 maybe?
                            See here some screenshots http://puu.sh/6g5M2.jpg and http://puu.sh/6g5Nx.jpg. I tried it on several models.
                            Hope you can help me.
                            • tt_suT
                              tt_su
                              Can you share a test model?
                              • Y
                                Yucon
                                Yes ofcourse, here http://www.yucon.nl/projecten/testfile.zip you can download the file. If I want to replace the trees for a simpel box you can see that the boxes will be placed on a different location.
                                Daan
                                • Y
                                  Yucon
                                  Hi Tom,
                                  Did you download the test file? Do you understand the problem?
                                  Daan
                                  • tt_suT
                                    tt_su
                                    You tried to replace the trees with what? With component?
                                    (Btw - your SKP file that you shared wsa 40MB - but when I purged it (Model Info > Statistics > Purge Unused it became only 18MB.)
                                    Also, what version do you have? I'm not sure if I've published the latest on SketchUcation yet. The latest version is 1.1.0.
                                    • TIGT
                                      The PluginStore version is v1.0.0 - as it is the title to this thread... 😕
                                      • tt_suT
                                        tt_su
                                        Ackh! Then it's one of the about 20 I need to update on SCF... 😞
                                        • Y
                                          Yucon
                                          I am trying to replace the tree for a simple box component. I think the problem will besolved if you upload the latest version.
                                          Many tx
                                          • tt_suT
                                            tt_su
                                            The latest is available on Extension Warehouse at the moment. I'm currently too overloaded to update my plugins on SCF. Probably won't happen until February.
                                            • 2 / 3
