    How to use .VISMAT files for Vray for Sketchup
    renderpluginsextensions
    19 Posts 15 Posters 95.2k Views 15 Watching
    • N Offline
      Nilsvdc
      Hi guys!
      I recently downloaded a package of interesting .VISMAT material files tu use for Vray for sketchup. I tried to figure out how to use them, but i really don't know how????
      Can somebody help me?
      Thanks!
      • EarthMoverE Offline
        EarthMover
        In sketchup, assign a material/color to face and name the material. Open the Vray material editor and find the material you want to replace with the .vismat. Right click on it and choose import material. Browse to and select the .vismat. That's it. Quick and simple once you get the hang of it.
        Content Creator at Skapeup
        • N Offline
          Nilsvdc
          Allright, it works... thanks a lot for the help!
            RUSSELL.CALL
            Hey there. I just downloaded the materials pack and followed the steps above. The material is displayed in the preview fine and changes in the sketchup model but when I go to render I get an error message. The error heading is "ASGvis" and the message reads, "We have encountered errors while trying to render. Please check the error log for more details."
            I know this is a vague message but any help would be greatly appreciated.
            It might be helpful to note that I don't have sketchup 8 pro and am currently running the trial of vray but I've had no problems with rendering before this.
            Thanks!
              junior_architect
              Thanks!
              Hi there i am having the same problem as RUSSELL.CALL please let me know if this issue has been resolved. Thanks.
              • V Offline
                valerostudio
                What kind of material is it? Could be an issue using a new material with the old V-ray. I do believe you will need the latest plugin to use some of the newer cooler materials.
                  junior_architect
                  I used these materials....
                  http://www.vray.com/free_vray_tools/vismat_material_collection/
                    Scostumatu
                    Hi all
                    it may be because the vismat is calling for a bitmap material associated with the vismat.
                    From memory, those vismats provided do NOT have the bitmaps included.
                    You can review the exact error here:
                    C:\ProgramData\ASGVIS\VfS\vfs_stderr.txt
                    If you cannot open it (due to the program using it), then make a copy of this file and review it that way!
                    Hope this helps
                    S
                      junior_architect
                      Thanks will check up on those bitmaps...also i think the problem was in some components downloaded from the sketch up warehouse. Once i deleted these, sketch up was rendering perfectly...(well a little slow but rendering nevertheless).
                        theverylastofart
                        Hey, just had the same problem with the import of the VISMAT material collection.
                        when you encounter an error log, just go to - plugins - vray - render - clear the list of materials. and start your process again. sometimes i just search the warehouse for materials added to some furniture and extract it and use it th "colors in model" panel of the materials. safe and works without crashing because the information is always saved in the material editor of vray.
                        hope it helps
                          junior_architect
                          Thanks for all your help.
                            tinoguit
                            [img]file:///C:/Users/HP/Desktop/Nouveau%20dossier/Capture.JPG[/img]
                              Tino, you cannot insert or link to a file on your computer. You need to upload it as an attachment - see the attachment tab under the post text area you are writing your post.
                              • 1 Offline
                                10103e
                                Hi all, I just tried to use vismat in rendering, although I can now see the new material in rendering, but in the model , it is still the older material lol
                                • TedVitale_CGT Offline
                                  TedVitale_CG
                                  Sorry guys, vray.com is not a Chaos Group website. It is a reseller that we are not directly associated with, and they still have a lot of old (bad) materials available on the site. If you are looking for the V-Ray Material collection you can log in and download it from the materials section of http://www.chaosgroup.com. You may also be interested in the website http://www.sketchuptexture.com, they are also not associated with Chaos Group, but it is a very handy resource.
                                  I hope this helps!
                                  Ted Vitale
                                  Owner | Creative Director
                                  http://www.voxl.vision
                                  • H Offline
                                    hvanessen
                                    When i import the New vismat materialen my preview is allright, but in the sketchup model everything is Grey. I also can't rotate the texturen.
                                    What is the problem
                                    • andybotA Offline
                                      andybot
                                      What is the problem
                                      That vismat may have a "blend" material in the diffuse layer, which means SU can't access the texture to adjust the positioning in the model. Try changing the diffuse layer to Texbitmap and select the image file for your texture.
                                      If that isn't the problem - maybe you can post a screenshot of your vray material settings.
                                      • Y Offline
                                        yaxaku
                                        I had a similar experience with Andybot. In addition, all my renderings come out dark as if I changed the settings to night.
                                        Please help!
                                          MDG237
                                          Hi everyone. I have a similar problem to hvanessen. My vismat materials are grey, but look fine in the preview. It's set to a Textbitmap in the Diffuse layer too. How do I solve this. It does this with all my vismats. Im using Sketchup 2016 and Vray
