    How to use .VISMAT files for Vray for Sketchup
    renderpluginsextensions
    19 Posts 15 Posters 95.2k Views 15 Watching
    • N Offline
      Nilsvdc
      Allright, it works... thanks a lot for the help!
        RUSSELL.CALL
        Hey there. I just downloaded the materials pack and followed the steps above. The material is displayed in the preview fine and changes in the sketchup model but when I go to render I get an error message. The error heading is "ASGvis" and the message reads, "We have encountered errors while trying to render. Please check the error log for more details."
        I know this is a vague message but any help would be greatly appreciated.
        It might be helpful to note that I don't have sketchup 8 pro and am currently running the trial of vray but I've had no problems with rendering before this.
          junior_architect
          Hi there i am having the same problem as RUSSELL.CALL please let me know if this issue has been resolved. Thanks.
          • V Offline
            valerostudio
            What kind of material is it? Could be an issue using a new material with the old V-ray. I do believe you will need the latest plugin to use some of the newer cooler materials.
              junior_architect
              I used these materials....
              403 Forbidden
              (www.vray.com)
                Scostumatu
                Hi all
                it may be because the vismat is calling for a bitmap material associated with the vismat.
                From memory, those vismats provided do NOT have the bitmaps included.
                You can review the exact error here:
                C:\ProgramData\ASGVIS\VfS\vfs_stderr.txt
                If you cannot open it (due to the program using it), then make a copy of this file and review it that way!
                Hope this helps
                S
                  junior_architect
                  Thanks will check up on those bitmaps...also i think the problem was in some components downloaded from the sketch up warehouse. Once i deleted these, sketch up was rendering perfectly...(well a little slow but rendering nevertheless).
                    theverylastofart
                    Hey, just had the same problem with the import of the VISMAT material collection.
                    when you encounter an error log, just go to - plugins - vray - render - clear the list of materials. and start your process again. sometimes i just search the warehouse for materials added to some furniture and extract it and use it th "colors in model" panel of the materials. safe and works without crashing because the information is always saved in the material editor of vray.
                    hope it helps
                      junior_architect
                      Thanks for all your help.
                        tinoguit
                        [img]file:///C:/Users/HP/Desktop/Nouveau%20dossier/Capture.JPG[/img]
                          Tino, you cannot insert or link to a file on your computer. You need to upload it as an attachment - see the attachment tab under the post text area you are writing your post.
                          • 1 Offline
                            10103e
                            Hi all, I just tried to use vismat in rendering, although I can now see the new material in rendering, but in the model , it is still the older material lol
                            • TedVitale_CGT Offline
                              TedVitale_CG
                              Sorry guys, vray.com is not a Chaos Group website. It is a reseller that we are not directly associated with, and they still have a lot of old (bad) materials available on the site. If you are looking for the V-Ray Material collection you can log in and download it from the materials section of http://www.chaosgroup.com. You may also be interested in the website http://www.sketchuptexture.com, they are also not associated with Chaos Group, but it is a very handy resource.
                              I hope this helps!
                              Ted Vitale
                              Owner | Creative Director
                              http://www.voxl.vision
                              • H Offline
                                hvanessen
                                When i import the New vismat materialen my preview is allright, but in the sketchup model everything is Grey. I also can't rotate the texturen.
                                What is the problem
                                • andybotA Offline
                                  andybot
                                  What is the problem
                                  That vismat may have a "blend" material in the diffuse layer, which means SU can't access the texture to adjust the positioning in the model. Try changing the diffuse layer to Texbitmap and select the image file for your texture.
                                  If that isn't the problem - maybe you can post a screenshot of your vray material settings.
                                  • Y Offline
                                    yaxaku
                                    I had a similar experience with Andybot. In addition, all my renderings come out dark as if I changed the settings to night.
                                    Please help!
                                      MDG237
                                      Hi everyone. I have a similar problem to hvanessen. My vismat materials are grey, but look fine in the preview. It's set to a Textbitmap in the Diffuse layer too. How do I solve this. It does this with all my vismats. Im using Sketchup 2016 and Vray
