    Aircraft
    18 Posts 6 Posters 2.1k Views 6 Watching
    • F Offline
      fireplug1111
      I'm in need of some help. I'm a Remote Control helicopter pilot. I'm going to build a U.S.Army UH-1D Huey helicopter from scratch. I need someone to design the "D" model heli with cut aways about every foot or so. This way I can cut out formers and use that as a template to start the mold making process. Basicly what I need is a cross section view looking from the front to back about every foot on a full size Huey. I also need a top to bottom.
      I have no Idea how to do this. If anyone is looking to help I would greatly appreciate it. If you want I can send you a front view side view and a top view with the actual measurments of the real helicopter.
      Thanking you in advance
      Alan
        Hi Alan,
        Something like this?
        http://forums.sketchucation.com/viewtopic.php?f=81&t=12513&p=90109
        • F Offline
          fireplug1111
          Thats excatly what I need. I need the ones of the bulkheads ( formers ) like in the 4th and 5th pictures, is there a way I can get them in a front view so I can print them out and use them? This is what I need to use them for . Look at this link-- http://www.helifreak.com/showthread.php?t=127202
          I do have a drawing of the helicopter I need.
          Thanks Alan
            Well, if you have the model, there are plugins that can do that in the variation you want. There is a "Slicer" plugin for instance (by our regular contributor, TIG here) in the Ruby Library Depot.
            http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_edi_page.htm
            • F Offline
              fireplug1111
              The problem is I have no idea how to do any of this. I'm totally new I told a computer friend of mine what I wanted to do and he told me about Sketchup. I googled the forums and figured I would see if anyone would take this on for me. I dont need all the details like your Hawk, just the formers ( or slicer ). Like I said I need someone to help me with this. I'd be glad to pay for your time.
              Thanks Alan
              • F Offline
                fireplug1111
                • F Offline
                  fireplug1111
                  Anyone Please? I need help.
                  Thanks Alan
                    Hi Alan,
                    I think people are waiting for you to startdoing it and then they can chime in with helpful suggestions.
                    So start something like this (with the "shoebox" technique): make a simple box where you apply the images (as high resolution as possible) of your helicopter as below. Then start retracing the outlines of it as precisely as possible. You can use Fredo's Bezier Spline plugin for smoother curves for it.
                      There are several good Car modeling tutorials using techniques of pasting ortho' views onto a box... do a Search on this site for them - unfortunately 'car' is too short to search for, so browse the Tutorial Forum - e.g. http://forums.sketchucation.com/viewtopic.php?f=18&t=3961&st=0&sk=t&sd=d&start=15
                      A Car is quite like a Plane ?
                      • F Offline
                        fireplug1111
                        Ok I can do that now that I am pointed in the right direction. Next question, Do I need Sketchup pro or can this be done with Sketchup 7?
                          you can do with the free version. the pro is only required for exporting/importing various file formats.
                            Movies (animation export) is also possible with the free version (since v.6).
                            So definitely the free version will get you anywhere - with modelling at least.
                              Almost certainly v7.1 free will do everything you need - it has all of the tools - unless you want to make dynamic-components, export dwg files or use Layout for presentations etc - then Pro kicks in - but I'd expect 'free' to be more than enough for now...
                              You would also benefit from some Plugins to help make complex mesh surfaces more easily [e.g. my ExtrudeEdgesByRails which lets you pick a profile, two rails and a melding-profile as lines [as curves], and make a smooth meshed surface as you might find in a car or plane outer skin] - they'll all work in 'free' too.
                              However, I recommend that you get the basics learnt first, and then come back about the complexities... πŸ˜‰
                              • F Offline
                                fireplug1111
                                Really all I need to do is take a front view and slice it up about every 6 inches or so using the true dimentions. I need this so I can print them out and use them as a template to build a R/C UH-1D helicopter. I guess this is way over my head and I might have to give up. I have no idea how to do any of this. That is why I asked for help and see if someone could do it for me.
                                Thanks anyways guys.
                                  You could probably find a suitable free model on the 3D Warehouse that would do ?
                                  http://sketchup.google.com/3dwarehouse/search?q=helicopter+huey&styp=m&btnG=Search&reps=2
                                  http://sketchup.google.com/3dwarehouse/details?mid=5ae11b134934f08a643ae903098a314&prevstart=0 ???
                                  Perhaps you could do a bit of adjusting, simplification etc...
                                  Then use Slicer ruby to make the slices - it even lays them out for you to cut out - and 'bob's your uncle' πŸ˜„
                                  http://forums.sketchucation.com/viewtopic.php?p=16694#p16694
                                  • F Offline
                                    fireplug1111
                                    TIG- I tired to use slicer but it wont work. It says invalid volume and wont do anything... I dont like the Huey's in the Warehouse they dont look right. Thanks for the help anywyas.
                                    • K Offline
                                      KXI System
                                      Actually, I might think about making this model... as soon as I free up my schedule, which might be in a week or two.
                                      I know what I'm doing, just that I'm lacking experience. So I might not be the top choice, if you want a pro find solo (lol rime!).
                                      Getting the perfect sig is hard...
                                      Google it!
                                      • O Offline
                                        outland86
                                        Bob's your Uncle: roughly translates to 'there ya go - that's all there is to it!' Just press this big red button that says 'Launch Missile', and "Bob's your uncle".
