    Aircraft
    18 Posts 6 Posters 2.3k Views 6 Watching
      There are several good Car modeling tutorials using techniques of pasting ortho' views onto a box... do a Search on this site for them - unfortunately 'car' is too short to search for, so browse the Tutorial Forum - e.g. http://forums.sketchucation.com/viewtopic.php?f=18&t=3961&st=0&sk=t&sd=d&start=15
      A Car is quite like a Plane ?
      • F
        fireplug1111
        Ok I can do that now that I am pointed in the right direction. Next question, Do I need Sketchup pro or can this be done with Sketchup 7?
          you can do with the free version. the pro is only required for exporting/importing various file formats.
          • GaieusG
            Movies (animation export) is also possible with the free version (since v.6).
            So definitely the free version will get you anywhere - with modelling at least.
              Almost certainly v7.1 free will do everything you need - it has all of the tools - unless you want to make dynamic-components, export dwg files or use Layout for presentations etc - then Pro kicks in - but I'd expect 'free' to be more than enough for now...
              You would also benefit from some Plugins to help make complex mesh surfaces more easily [e.g. my ExtrudeEdgesByRails which lets you pick a profile, two rails and a melding-profile as lines [as curves], and make a smooth meshed surface as you might find in a car or plane outer skin] - they'll all work in 'free' too.
              However, I recommend that you get the basics learnt first, and then come back about the complexities... πŸ˜‰
              • F
                fireplug1111
                Really all I need to do is take a front view and slice it up about every 6 inches or so using the true dimentions. I need this so I can print them out and use them as a template to build a R/C UH-1D helicopter. I guess this is way over my head and I might have to give up. I have no idea how to do any of this. That is why I asked for help and see if someone could do it for me.
                Thanks anyways guys.
                  You could probably find a suitable free model on the 3D Warehouse that would do ?
                  http://sketchup.google.com/3dwarehouse/search?q=helicopter+huey&styp=m&btnG=Search&reps=2
                  http://sketchup.google.com/3dwarehouse/details?mid=5ae11b134934f08a643ae903098a314&prevstart=0 ???
                  Perhaps you could do a bit of adjusting, simplification etc...
                  Then use Slicer ruby to make the slices - it even lays them out for you to cut out - and 'bob's your uncle' πŸ˜„
                  http://forums.sketchucation.com/viewtopic.php?p=16694#p16694
                  • F
                    fireplug1111
                    TIG- I tired to use slicer but it wont work. It says invalid volume and wont do anything... I dont like the Huey's in the Warehouse they dont look right. Thanks for the help anywyas.
                    • K
                      KXI System
                      Actually, I might think about making this model... as soon as I free up my schedule, which might be in a week or two.
                      I know what I'm doing, just that I'm lacking experience. So I might not be the top choice, if you want a pro find solo (lol rime!).
                      Getting the perfect sig is hard...
                      Google it!
                      • O
                        outland86
                        Bob's your Uncle: roughly translates to 'there ya go - that's all there is to it!' Just press this big red button that says 'Launch Missile', and "Bob's your uncle".
