    [Plugin] Edge Tools
    211 Posts 74 Posters 276.0k Views 74 Watching
      MartinK
      Thanks for the plugin. I'm getting ready to try the simplify curves routine on a large number of contours. As always, these plugins you and others generously make available are great time savers, and I appreciate your efforts. Thanks again. πŸ‘
      • xiombargX Offline
        xiombarg
        Man, I am just amazed. Your plugins are the zen that I've wished Sketchup had. Great work, seriously.
          rock1
          on dividing a face with lines is there a way that the divisions go at a fixed distance. for. e.g. we copy one line at 1m and repeat copy it, we press 6x to make 6 copies for it. the same thing i want to do with this plugin, hw is this possible ❓
          Signature removed by SCF Admin
            By using the VCB - similar to how you use the native Move tool.
              chango70
              Very useful, thank you!
              • jeff hammondJ Offline
                jeff hammond
                jeez 😲 .. i missed this plugin too.. some awesome stuff in there!
                thanks.
                re: this post:
                http://forums.sketchucation.com/viewtopic.php?p=365178#p365178
                i think what i'd like for it to do might complicate the 'simplify curves' option.. it works great now in many cases (setting to 0 which joins all applicable edges)
                what i'd like to be able to do is have it weld everything except there would be some sort of filter(?) in place that won't weld anything less than a certain angle... like if the angle between two edges is sharper than, say, 1 radian then the edges won't be joined..
                just an idea and one that i personally wouldn't use very often (and i imagine i'd use it more than most people.. maybe once or twice during a heavy modeling session..)
                if you like the idea then go for it.. otherwise, don't sweat it πŸ˜„
                dotdotdot
                • H Offline
                  hhdk
                  So useful! it's also perfect for solving line problems that occurs on autocad imports.
                  • guanjinG Offline
                    guanjin
                    The first tool, if the offset of the linear, such as CAD
                    CAD.gifPowerful, can change? Perhaps my request is too much! ! πŸ˜„
                    I come from China, is to learn
                      That you can do with the native Move - using the copy array modifier.
                      • guanjinG Offline
                        guanjin
                        Not quite understand,Can only offset the surface line,As above, and CAD functions.I'm just too greedy,Tool itself is very strong
                          SketchUp's Move Tool
                          http://support.google.com/sketchup/bin/answer.py?hl=en&answer=94867
                          You just need to do a linear array to do what you showed in the CAD animation.
                          • guanjinG Offline
                            guanjin
                            Thank you thom thom
                            This is very complex, πŸ˜„ πŸ˜„
                            • brookefoxB Offline
                              brookefox
                              Please see the image for a use of 'face divide' for quickly uniformly hatching a face. It works very well for this as I understand it: click an edge, move to the farthest edge to check distance (and alternatively input a distance), then divide by a number which will result in the size hatch you want.
                              Thank you.
                              FORGET THIS: Any chance for a mod so it can be used like copy multiple, thereby saving a step, or is this already possible? I see up above that you say it is... I guess your way only takes two steps, just like copy multiple. So, yeah, forget it.edge tools -1.JPG
                              With this hatch roads to be abandoned are indicated. The potential transparency of such edge hatches reads much better than textures, IMO. Yes, I agree, it is surely not the best way to do this, creating as it does 500 or so new edges.edge tools -2.JPG
                              ~ Brooke
                              • F Offline
                                function
                                Hi, I updated to ttLib 2.6 and the new edge tool and it no longer gives me thr heads up display or red circles 😞
                                  Any errors in the Ruby Console?
                                  Are you sure you installed the updates correctly?
                                  • F Offline
                                    function
                                    Ill have to look when I get home. I installed fredos multi directory at the time, and since it wasnt working I installed it back to root plug folder.. Maybe it is the division of the lib in different directories
                                      rv1974
                                      I'm really missing 'divide face' tool working with multiple (connected) edges. πŸ˜’
                                        Wouldn't Tools on Surface do what you want there?
                                          rv1974
                                          doh! I forgot TOS offset works non-curves. thanks!
                                            rv1974
                                            I re-found why TOS offset is no good for me. Can one make it to extend the resulted curve to the face border?
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 7 / 11
