    [Plugin] Edge Tools
    211 Posts 74 Posters 328.9k Views 74 Watching
    • thomthomT
      Overview
      Collection of some small edge tools I needed for my work.
      Access
      Tools > Edge Tools
      View > Toolbars > Edge Tools
      Features
      [anchor=divide-face:wwgv9kwm]Divide Face (v1.1.0)[/anchor:wwgv9kwm]
      [flash=640,505:wwgv9kwm]http://www.youtube.com/v/hM7t6t1cCkY&hl=en_GB&fs=1&hd=1[/flash:wwgv9kwm]
      [anchor=close-gaps:wwgv9kwm]Close Gaps (v2.0.0)[/anchor:wwgv9kwm]
      [flash=640,385:wwgv9kwm]http://www.youtube.com/v/yRPsLRGQwNQ?fs=1&hl=en_US[/flash:wwgv9kwm]
      Co-linear Edges
      Select any sets of connected edges. (Other entities and edges that form loops are ignored.) For each set, the points between the first and last point will be made co-linear to the first and last point. You can also choose to restrict the adjustments of the points to a given direction.
      Curve Simplification
      "Curve" does here not mean a Curve entity. You don't have to weld anything together. It's just a series of connected edges selected. You can select multiple curves to run this command on. Good for after importing CAD plans of contours.
      [flash=640,385:wwgv9kwm]http://www.youtube.com/v/-WzsUQTonmk?fs=1&hl=en_US[/flash:wwgv9kwm]
      Algorithm used is the http://en.wikipedia.org/wiki/Ramer-Douglas-Peucker_algorithm
      When you are prompted for an epsilon value it refers to the distance b in the above illustration. It's max distance any point is allowed to deviate from the simplified polyline.
      The curves must not connect to anything else and not fork. The resulting simplified curve is created as a Curve entity.
      Note: The plugin does not check for forking curves. If you see unexpected behaviour - check that your selected curves doesn't fork.
      Requirements
      • SketchUp 7 or newer - ( Other versions untested )
      • TT_Lib2 (v2.5.4)
      404 Not Found
      (sketchucation.com)
      [anchor=footprint goto=footprint:wwgv9kwm]Footprint[/anchor:wwgv9kwm]
      http://forums.sketchucation.com/download/file.php?id=53762
      <Sketchup>/Plugins/
      http://forums.sketchucation.com/download/file.php?id=53763
      tt_edgetools.rb
      TT_EdgeTools
      Images
      close_gaps.rb
      core.rb
      divider.rb
      make_colinear.rb
      simplify.rb
      http://forums.sketchucation.com/download/file.php?id=53761
      • thomthomT
        Small bug-fix.
        • GaieusG
          This looks very useful, thanks Thom. I remember cases when I had to move vertices one by one manually to end up with something this plugin is capable of. πŸ‘
          • wind-borneW
            wind-borne
            Thanks, this will be extremely useful in my work ❗ and outside of work πŸ˜„
            "To read between the lines was easier than to follow the text."OSX 10.11.6
            %(#BF80BF)[SU 8 pro
            • K
              Khai
              so just so I'm sure, this aligns vertices to one straight line?
              if so this is a great import clean up tool...
              • thomthomT
                yes.
                • K
                  Khai
                  oh you just made my day...
                  I'm getting a lot of faces divided on import bringing my work over from trueSpace - in tS, they are quads and there's no issue.. but in SU, they are tri'd.. the vertices are ever so slightly out of alignment.. tS does not care... SU does... this should then fix those faces πŸ˜„
                    cool tools sets! πŸ‘
                    • EarthMoverE
                      EarthMover
                      Thanks Thomthom. Very useful. Max has something similar to straighten edges in the edit poly modifier called Make Planar. Adding the Make Colinear also is a nice touch.
                      Content Creator at Skapeup
                      • A
                        a4chitect
                        perfect tool - thanks!!!
                        • simon le bonS
                          simon le bon
                          Hi Thomas,
                          You are incredibly productive and innovative.
                          One more time, this one promise to be strongly useful (I'm reminding the number of times this tools was missing to me)..
                          my thanks and my respect,
                          simon.
                          • thomthomT
                            @simon le bon said:
                            Hi Thomas,
                            simon.
                            Thanks for your kind words.
                            Co-linear Edges, or Curve Simplification?
                            • P
                              Panga
                              Thanks for this new tool !! I'm sure i'll find cases in which it'll be usefull.
                              • simon le bonS
                                simon le bon
                                Co-linear πŸ‘ πŸ˜‰
                                • PixeroP
                                  Pixero
                                  Wow, I've totally missed this. Great plugin.
                                  • mknorrM
                                    mknorr
                                    I am sure this is a stupid question but where does one get this plugin? None of the links here take me anywhere.
                                    • thomthomT
                                      At the end of the first post in the thread. Look for the cookie. πŸ˜‰
                                      • mknorrM
                                        mknorr
                                        See, it was a stupid question 😳
                                        Thank you Sir
                                        • thomthomT
                                          Update v1.1.0
                                          New:
                                          • Divide Face (See video in main post.)
                                            That is very good! πŸ‘ 😎
                                            • 10
                                            • 11
                                            • 1 / 11
