    Import Max models (evermotion) to Sketchup
    extensions
    14 Posts 7 Posters 13.2k Views 7 Watching
    • W
      wawo_kalbo
      Hi all.
      need some help, my office uses autodesk viz 2008 and they have a few evermotion archmodels. i only use sketchup coz i dont know how to use viz/max and ive been wanting to use some high poly 3d models.
      anyone know how to import the evermotion models to skp? ive tried to export the model to 3ds file and i got the prompt "object has too many faces (more than 64K) to export" so when i import to skp (as a 3ds object) i only get part of the model, or sometimes parts of the model are scattered all over the place.
      hope somebody can help me on this. thanks a lot.
      • thomthomT
        Have you tried the new collada format in SU7.1?
        • R
          remus
          dwg/dxf is worth a try as well.
          • W
            wawo_kalbo
            Hi remus, ive tried export as dwg/dxf and this is the result
            "object contains more vertices than are supported in a DWG or DXF file; the current maximum is 32,767 in a single object.
            this object will be skipped during export"
            and when i did export the sofa, only the legs were successfully exported. the hi poly cushion was not.
            @thom: collada? im using the free sketchup version. i checked the export rollout for viz and there is no collada (or maybe i missed it)...
            • GaieusG
              kmz and dae are collada formats. do you have those?
              • W
                wawo_kalbo
                I do have (on Viz) export to Autodesk (*.FBX, *.DAE)
                and yup i managed to export without any error (didnt bother to touch the settings)
                but when i tried to import to sketchup it cannot be recognized as a supported file format because my sketchup import rollout only has Google Earth (*.KMZ, *.DAE)
                sorry im such an idiot 👊 really want to use some hi poly models badly as my office has quite a bit of evermotion archmodels..
                • GaieusG
                  Well, that's it then (unless I totally misunderstand something).
                  So you say viz can export dae - and SU can import dae (in the latest version - 7.1 - at least).
                  • W
                    wawo_kalbo
                    No not really sorry if my post was a bit misleading.
                    i meant whatever the file viz exported (as .fbx, .dae), sketchup wasnt able to import.. coz i think sketchup can only read (.kmz, .dae) and not the former..
                    sigh
                    • D
                      dacad
                      I´m also interested in these. If you can manage to import a high poly model from other app please share after that.
                      You can try a obj importer plugin that's posted in this forum (use the search). You'll probably loose the textures and UVs, but not that really matters since all importers on sketchup won't keep them anyway (maybe unless it's just a box) and officially they're importers suck.
                      we really need a oficial and realiable obj importer google...again no one pays $500 for importers, specially if they suck...
                      P.S.: sorry the rant...bad day at the office...
                      • R
                        remus
                        TIGs written an .obj importer that i hear works pretty well (keeps UVs etc.) although id be hesitant to use a ruby importer to try and import something that large.
                        • EarthMoverE
                          EarthMover
                          I have done this successfully. I have a couple different Archmodel collections and in particular the potted plant collection I've used in SU. I typically export it as .obj, reduce the polycount in another app, then import via TIG's .obj importer, which will preserve the UV's. It does take a while to import though.
                          Content Creator at Skapeup
                          • W
                            wawo_kalbo
                            Thanks Earthmover. mind if i ask you which app you use to reduce the polycount before you import to SU? thanks for the tips, ill definitely give TIG's importer a whirl and update you if my attempts were successful.
                            • W
                              wawo_kalbo
                              ive tested Adam's method of importing the max models. im using Viz 2008 to open the evermotion models and export them to .OBJ using this;
                              http://www.cgarchitect.com/vb/26630-viz-export-obj.html?=
                              afterwards i use TIG's import .OBJ ruby downloaded from the ruby forum
                              it takes quite sometime for it to import but i manage to keep everything intact 😄 thanks to everybody who helped
                              just one last question, how do i reduce to polycount so i can import the OBJ faster in skp? i have Deep Exploration 5.0. any tips?
                              thanks thanks thanks!!
                              • S
                                superian111
                                I have had this problem and the only way i managed to get arround it was as follows.
                                You need to open the model in max weld all the components together and save as a 3ds.
                                Then sketchup will be able to inport it. If you dont weld the parts it scatters the parts
                                all over the place. Dont stress when you weld it, when you open it in SU it still
                                sees the parts as seperate pieces and if you triple click the parts remain as seperate pieces.
                                However if the model is too complicated or has a high poly count there is NO way to inport it
                                sketchup just doesnt handle it 😞 but i do manage to get most archmodels inported.
