    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 170.5k Views 73 Watching
      ๐Ÿ‘
        martinvz
        My appoligies, I did not alter anything in the plugin except the fix. (wanted to help the people out that did not know how to fix the plugin)
        Because the plugin did not get any update I thought the author did not update the plugin anymore. (last update was a long long time ago)
        Next time I will pm the author first.
          Lianam
          Thanks for the plugin...Just found it. I am using sketch-up 8 and trying to learn Blender also. I want to be able to texture in blender what I can not in sketch-up the way I want to or that is my main hope. ๐Ÿ˜„ I will give it a try soon.
          Lianam
          • P Offline
            paolo
            Hi everyone, sorry for the silly question but I'm learning using UV tools by Whaat (thanks a lot to him) with Headus UVlayout although is for Architectural purpose (simple geometry) I wonder if using this method will reduce the file size comparing to editing textures to Photoshop in Sketchup? any way I have a problem when loading the geometry in UVlayout cause some openings do not appear, please see the pictures.
            Thanks a lot for any help.
            • W Offline
              Whaat
              [attachment=0:3moajcy4]<!-- ia0 -->SU to UVlayout.jpg<!-- ia0 -->[/attachment:3moajcy4]
              I think there might be a bug with the OBJ export for faces with more than four vertices. Try manually dividing faces into quads before exporting and see what happens?
              • P Offline
                paolo
                ๐Ÿ˜ฎ Whaat thanks for your quick reply, it works manually dividing face into quads although is a bit of a pain... I wonder if your SketchUV plugin will do the job 'automatically'.
                • W Offline
                  Whaat
                  Sorry, although SketchUV has a nice triangulation feature that will split all faces into triangles, it has a bit of trouble with faces that have 'holes'
                  • W Offline
                    weblogin
                    Thanks, lets try it!
                    • E Offline
                      eeum8244
                      thank you
                      • Leonard96L Offline
                        Leonard96
                        @gaieus said:
                        @zunkian said:
                        ...I then right click on the model, selected the UV tools plugin and selected spherical map...
                        This is the wrong topic then. That's UVTools 1:
                        http://forums.sketchucation.com/viewtopic.php?t=10404
                        ๐Ÿ˜„
                        And yes, sometimes that plugin does not work perfectly. Can you attach the model?
                        Hy Gav! I need help!!! SketchUP 8 crashes because of UV tool 1 when I want to mapp a texture(I want to model planet Jupiter).Sometimes works sometimes crashes, but now...it crashes! ๐Ÿ˜  ๐Ÿ˜  Hope to find a solution!Here is my modelUntitled.skp Here are my models on 3D warehouse:http://sketchup.google.com/3dwarehouse/cldetails?mid=ded937a45a821f58178b53c3b6bafa41
                        My secret weapon is creativity
                        • P Offline
                          povmaniac
                          Hi guys..
                          I add specific code for launch RoadKill from menu option.
                          For option dialog..
                          if( not file_loaded?("UVtools.rb") )
                          	menu = UI.menu("Plugins").add_submenu("UV Tools")
                          	menu.add_item("Export UVs to OBJ")  { UVtools.start_bridge()}
                          	menu.add_item("Launch RoadKill")  { UVtools.runroad()} # add RoadKill option
                          	menu.add_item("Import UVs from OBJ ") { UVtools.return_bridge() }
                          	UI.add_context_menu_handler {|menu|
                          		ents=Sketchup.active_model.selection
                          		sel=Sketchup.active_model.selection.first
                          		sub=menu.add_submenu("UV Tools")
                          		sub.add_item("Spherical Map") {(UVtools.new.spherical_map(ents))}
                          		sub.add_item("Cylindrical Map") {(UVtools.new.cylindrical_map(ents))}
                          ..for launch Roadkill.
                          ## povman; add code for launch RoadKill from the 'menu' option
                          	def self.runroad()
                          		# Roadkill arguments ( from RoadKill for Softimage);
                          		# -lscm or -abf
                          		# -fillholes or -notfillholes
                          		# -live or -notlive
                          		# a tipically command line;
                          		# "C;\RoadKill\RoadKill.exe" "obj_path,edge_path,-abf,-nofillholes,-live"
                          		obj_path=self.get_obj_path
                          		#TODO; create option dialog for arguments..
                          		roadpath=UI.openpanel("Path to RoadKill", "c;\\", ".exe")
                          		command_line = "\"#{roadpath}\" \"#{obj_path},,-lscm,-nofillholes,-live\""
                          		# for debug..
                          		puts command_line
                          		# run RoadKill..
                          		system(command_line)
                          Greetings..
                          Code::maniac!!
                            sketchusters
                            Hi guys where can I download the plugin => imp/exp for obj for SU8 ? ๐Ÿค“
                            • greenskpG Offline
                              greenskp
                              @povmaniac said:
                              Hi guys..
                              Hi povmaniac. Can you explain how to use your code for add this functionality?
                              I would like to use same function into Sketchuv but i don't know where more edit the code.
                              I changed the path to roadkill but nothing happen.
                              My SketchUp is 2014.
                              Launch Roadkill
                              • P Offline
                                petrusyap
                                Hi, I run into this small problem. Running Sketchup Pro 2014 on both my machines, my old good PC (Windows 8.1) and a MacBook Pro (running Windows 8.1SP on bootcamp). On PC, i can export the object and import and export UV into OBJ with no problem. However, on the bootcamp SketchUp, it simply got this error message "Unable to export UVs".
                                May I know what will be the problem? Will it be the permission for the folder the UVTools exporting the objects? Can we manually edit the folder where the plugin will export to and import from for the obj with UVs corrected?
                                Please forgive me for my poor english as it is not my main language. Thank you.
                                Regards,
                                Petrus
                                • massimoM Offline
                                  massimo Moderator
                                  Hi, use this one. It's better.
                                  • P Offline
                                    petrusyap
                                    @Massimo, Thank you for your kind suggestion ๐Ÿ˜„ It is surely a great plugin ๐Ÿ˜„
                                    • massimoM Offline
                                      massimo Moderator
                                      You're welcome. ๐Ÿ˜‰
                                      • V Offline
                                        Vizan
                                        Great bridge, but the uv map is imported distorted((
                                        • 6
                                        • 7
                                        • 8
                                        • 9
                                        • 10
                                        • 10 / 10
