    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 169.0k Views 73 Watching
      paolo
      Hi everyone, sorry for the silly question but I'm learning using UV tools by Whaat (thanks a lot to him) with Headus UVlayout although is for Architectural purpose (simple geometry) I wonder if using this method will reduce the file size comparing to editing textures to Photoshop in Sketchup? any way I have a problem when loading the geometry in UVlayout cause some openings do not appear, please see the pictures.
      Thanks a lot for any help.
      • W Offline
        Whaat
        [attachment=0:3moajcy4]<!-- ia0 -->SU to UVlayout.jpg<!-- ia0 -->[/attachment:3moajcy4]
        I think there might be a bug with the OBJ export for faces with more than four vertices. Try manually dividing faces into quads before exporting and see what happens?
          paolo
          ๐Ÿ˜ฎ Whaat thanks for your quick reply, it works manually dividing face into quads although is a bit of a pain... I wonder if your SketchUV plugin will do the job 'automatically'.
          • W Offline
            Whaat
            Sorry, although SketchUV has a nice triangulation feature that will split all faces into triangles, it has a bit of trouble with faces that have 'holes'
            • W Offline
              weblogin
              Thanks, lets try it!
              • E Offline
                eeum8244
                thank you
                • Leonard96L Offline
                  Leonard96
                  @gaieus said:
                  @zunkian said:
                  ...I then right click on the model, selected the UV tools plugin and selected spherical map...
                  This is the wrong topic then. That's UVTools 1:
                  http://forums.sketchucation.com/viewtopic.php?t=10404
                  ๐Ÿ˜„
                  And yes, sometimes that plugin does not work perfectly. Can you attach the model?
                  Hy Gav! I need help!!! SketchUP 8 crashes because of UV tool 1 when I want to mapp a texture(I want to model planet Jupiter).Sometimes works sometimes crashes, but now...it crashes! ๐Ÿ˜  ๐Ÿ˜  Hope to find a solution!Here is my modelUntitled.skp Here are my models on 3D warehouse:http://sketchup.google.com/3dwarehouse/cldetails?mid=ded937a45a821f58178b53c3b6bafa41
                  My secret weapon is creativity
                    povmaniac
                    Hi guys..
                    I add specific code for launch RoadKill from menu option.
                    For option dialog..
                    if( not file_loaded?("UVtools.rb") )
                    	menu = UI.menu("Plugins").add_submenu("UV Tools")
                    	menu.add_item("Export UVs to OBJ")  { UVtools.start_bridge()}
                    	menu.add_item("Launch RoadKill")  { UVtools.runroad()} # add RoadKill option
                    	menu.add_item("Import UVs from OBJ ") { UVtools.return_bridge() }
                    	UI.add_context_menu_handler {|menu|
                    		ents=Sketchup.active_model.selection
                    		sel=Sketchup.active_model.selection.first
                    		sub=menu.add_submenu("UV Tools")
                    		sub.add_item("Spherical Map") {(UVtools.new.spherical_map(ents))}
                    		sub.add_item("Cylindrical Map") {(UVtools.new.cylindrical_map(ents))}
                    ..for launch Roadkill.
                    ## povman; add code for launch RoadKill from the 'menu' option
                    	def self.runroad()
                    		# Roadkill arguments ( from RoadKill for Softimage);
                    		# -lscm or -abf
                    		# -fillholes or -notfillholes
                    		# -live or -notlive
                    		# a tipically command line;
                    		# "C;\RoadKill\RoadKill.exe" "obj_path,edge_path,-abf,-nofillholes,-live"
                    		obj_path=self.get_obj_path
                    		#TODO; create option dialog for arguments..
                    		roadpath=UI.openpanel("Path to RoadKill", "c;\\", ".exe")
                    		command_line = "\"#{roadpath}\" \"#{obj_path},,-lscm,-nofillholes,-live\""
                    		# for debug..
                    		puts command_line
                    		# run RoadKill..
                    		system(command_line)
                    Greetings..
                    Code::maniac!!
                      sketchusters
                      Hi guys where can I download the plugin => imp/exp for obj for SU8 ? ๐Ÿค“
                      • greenskpG Offline
                        greenskp
                        @povmaniac said:
                        Hi guys..
                        Hi povmaniac. Can you explain how to use your code for add this functionality?
                        I would like to use same function into Sketchuv but i don't know where more edit the code.
                        I changed the path to roadkill but nothing happen.
                        My SketchUp is 2014.
                        Launch Roadkill
                          petrusyap
                          Hi, I run into this small problem. Running Sketchup Pro 2014 on both my machines, my old good PC (Windows 8.1) and a MacBook Pro (running Windows 8.1SP on bootcamp). On PC, i can export the object and import and export UV into OBJ with no problem. However, on the bootcamp SketchUp, it simply got this error message "Unable to export UVs".
                          May I know what will be the problem? Will it be the permission for the folder the UVTools exporting the objects? Can we manually edit the folder where the plugin will export to and import from for the obj with UVs corrected?
                          Please forgive me for my poor english as it is not my main language. Thank you.
                          Regards,
                          Petrus
                          • massimoM Offline
                            massimo Moderator
                            Hi, use this one. It's better.
                              petrusyap
                              @Massimo, Thank you for your kind suggestion ๐Ÿ˜„ It is surely a great plugin ๐Ÿ˜„
                              • massimoM Offline
                                massimo Moderator
                                You're welcome. ๐Ÿ˜‰
                                • V Offline
                                  Vizan
                                  Great bridge, but the uv map is imported distorted((
                                  • 10 / 10
