    [Plugin] UVTools 0.2 Pro (Beta) (Updated for SU6)
    198 Posts 73 Posters 171.6k Views 73 Watching
      martinvz
      I Guess Whaat does not update this plugin anymore.
      So here is a fixed version, this will solve the problem with Blender.
      Tested with blender 8, LithUnwrap and Blender.
      Version 0.3 works with Blender en SU8
      • dereiD Offline
        derei
        [attachment=0:1zrp5ppi]<!-- ia0 -->UVtools.rb<!-- ia0 -->[/attachment:1zrp5ppi]
        What exactly is fixed?
          http://forums.sketchucation.com/viewtopic.php?p=361512#p361512
          • dereiD Offline
            derei
            LOL ! i was looking around about "the glitch that needed fix", the page before, two pages before...but somehow I missed that ๐Ÿ’š
              [attachment=0:3u0js31c]<!-- ia0 -->UVtools.rb<!-- ia0 -->[/attachment:3u0js31c]
              Did you get permission to redistribute the plugin?
                [attachment=0:14kr3u5k]<!-- ia0 -->UVtools.rb<!-- ia0 -->[/attachment:14kr3u5k]
                Pleae, read the plugin posting guidelines here:
                http://forums.sketchucation.com/viewtopic.php?p=204973#p204973
                Whaat is alive and active so he may consider incorporating some changes into his plugin but re-posting verions is not good.
                • W Offline
                  Whaat
                  [attachment=0:12f2k8sk]<!-- ia0 -->UVtools.rb<!-- ia0 -->[/attachment:12f2k8sk]
                  I apologize for not updated this plugin. You should be asking permission before you redistribute any plugins. However, I have decided to include your version in the top post of this thread (hmmmm...I guess I'm now redistributing your plugin... ๐Ÿ˜› ๐Ÿ˜† ) if you don't mind.
                  Thanks for providing a fix. I had tested the plugin with Blender before and I thought it worked fine but I guess I was wrong.
                    ๐Ÿ‘
                      martinvz
                      My appoligies, I did not alter anything in the plugin except the fix. (wanted to help the people out that did not know how to fix the plugin)
                      Because the plugin did not get any update I thought the author did not update the plugin anymore. (last update was a long long time ago)
                      Next time I will pm the author first.
                        Lianam
                        Thanks for the plugin...Just found it. I am using sketch-up 8 and trying to learn Blender also. I want to be able to texture in blender what I can not in sketch-up the way I want to or that is my main hope. ๐Ÿ˜„ I will give it a try soon.
                        Lianam
                          paolo
                          Hi everyone, sorry for the silly question but I'm learning using UV tools by Whaat (thanks a lot to him) with Headus UVlayout although is for Architectural purpose (simple geometry) I wonder if using this method will reduce the file size comparing to editing textures to Photoshop in Sketchup? any way I have a problem when loading the geometry in UVlayout cause some openings do not appear, please see the pictures.
                          Thanks a lot for any help.
                          • W Offline
                            Whaat
                            [attachment=0:3moajcy4]<!-- ia0 -->SU to UVlayout.jpg<!-- ia0 -->[/attachment:3moajcy4]
                            I think there might be a bug with the OBJ export for faces with more than four vertices. Try manually dividing faces into quads before exporting and see what happens?
                              paolo
                              ๐Ÿ˜ฎ Whaat thanks for your quick reply, it works manually dividing face into quads although is a bit of a pain... I wonder if your SketchUV plugin will do the job 'automatically'.
                              • W Offline
                                Whaat
                                Sorry, although SketchUV has a nice triangulation feature that will split all faces into triangles, it has a bit of trouble with faces that have 'holes'
                                • W Offline
                                  weblogin
                                  Thanks, lets try it!
                                  • E Offline
                                    eeum8244
                                    thank you
                                    • Leonard96L Offline
                                      Leonard96
                                      @gaieus said:
                                      @zunkian said:
                                      ...I then right click on the model, selected the UV tools plugin and selected spherical map...
                                      This is the wrong topic then. That's UVTools 1:
                                      http://forums.sketchucation.com/viewtopic.php?t=10404
                                      ๐Ÿ˜„
                                      And yes, sometimes that plugin does not work perfectly. Can you attach the model?
                                      Hy Gav! I need help!!! SketchUP 8 crashes because of UV tool 1 when I want to mapp a texture(I want to model planet Jupiter).Sometimes works sometimes crashes, but now...it crashes! ๐Ÿ˜  ๐Ÿ˜  Hope to find a solution!Here is my modelUntitled.skp Here are my models on 3D warehouse:http://sketchup.google.com/3dwarehouse/cldetails?mid=ded937a45a821f58178b53c3b6bafa41
                                      My secret weapon is creativity
                                        povmaniac
                                        Hi guys..
                                        I add specific code for launch RoadKill from menu option.
                                        For option dialog..
                                        if( not file_loaded?("UVtools.rb") )
                                        	menu = UI.menu("Plugins").add_submenu("UV Tools")
                                        	menu.add_item("Export UVs to OBJ")  { UVtools.start_bridge()}
                                        	menu.add_item("Launch RoadKill")  { UVtools.runroad()} # add RoadKill option
                                        	menu.add_item("Import UVs from OBJ ") { UVtools.return_bridge() }
                                        	UI.add_context_menu_handler {|menu|
                                        		ents=Sketchup.active_model.selection
                                        		sel=Sketchup.active_model.selection.first
                                        		sub=menu.add_submenu("UV Tools")
                                        		sub.add_item("Spherical Map") {(UVtools.new.spherical_map(ents))}
                                        		sub.add_item("Cylindrical Map") {(UVtools.new.cylindrical_map(ents))}
                                        ..for launch Roadkill.
                                        ## povman; add code for launch RoadKill from the 'menu' option
                                        	def self.runroad()
                                        		# Roadkill arguments ( from RoadKill for Softimage);
                                        		# -lscm or -abf
                                        		# -fillholes or -notfillholes
                                        		# -live or -notlive
                                        		# a tipically command line;
                                        		# "C;\RoadKill\RoadKill.exe" "obj_path,edge_path,-abf,-nofillholes,-live"
                                        		obj_path=self.get_obj_path
                                        		#TODO; create option dialog for arguments..
                                        		roadpath=UI.openpanel("Path to RoadKill", "c;\\", ".exe")
                                        		command_line = "\"#{roadpath}\" \"#{obj_path},,-lscm,-nofillholes,-live\""
                                        		# for debug..
                                        		puts command_line
                                        		# run RoadKill..
                                        		system(command_line)
                                        Greetings..
                                        Code::maniac!!
                                          sketchusters
                                          Hi guys where can I download the plugin => imp/exp for obj for SU8 ? ๐Ÿค“
                                          • greenskpG Offline
                                            greenskp
                                            @povmaniac said:
                                            Hi guys..
                                            Hi povmaniac. Can you explain how to use your code for add this functionality?
                                            I would like to use same function into Sketchuv but i don't know where more edit the code.
                                            I changed the path to roadkill but nothing happen.
                                            My SketchUp is 2014.
                                            Launch Roadkill
                                            • 10 / 10
