    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 378.7k Views 71 Watching
      Rip Tanion
      Awesome plugin! Thanks!
      Three attached curvesround_corner.pnground_corner.skp
        I don't understand you diagram.
        You can already do this ?
        Are you wanting some sort of 2-face FollowMe ? Just use the faces edges [welded into a curve] as your Rails ?
        With EEbyRv2 [that is about to be launched] you will be able to choose the Profile, Rail1 and Rail2 and then a 'Melding-Profile' that fixes the end form too - is that what you want ? It will allow a definite start and end profile location form to be predefined...
        • H Offline
          hsjzyangbin
          Hi,TIG,I have a idea that <extrude edges by rails> adds a path like this,thanks
          next:I wish it could be add rotate and scale function
          • H Offline
            hsjzyangbin
            Yes,it could be "2-face +2-path+FollowMe" 😍
            I also do not have this plug-in, I use the LATHE. RB command generates images shown, as you said, the first path to the same, choose the second Rails as a control Rails
            "lathe" you can see it http://www.sketchupbbs.com/thread-40382-1-1.html
            • charly2008C Offline
              charly2008
                I too have a lathe.rb that is somewhat similar...
                • H Offline
                  hsjzyangbin
                  希望我的提议对你的插件有用,谢谢!
                    @hsjzyangbin said:
                    希望我的提议对你的插件有用,谢谢!
                    Your proposal for my plug-in very useful, thank you!
                    • david_hD Offline
                      david_h
                      very fun indeed. Is there a toolbar? I get the command in my Plugins Tab, but Is there an onscreen toolbar as well?
                        No Toolbar yet OR webdialog BUT it's on the list - trying to get v2 and segmentation right first...
                          http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                          Here's v2 - now allows a final 'melding-profile' if desired and facets minimized...
                            Here's some examples of EEbyRails v2ExtrudeEdgesByRailsV2Examples.pngExtrudeEdgesByRailsV2Examples.skp
                            • EarthMoverE Offline
                              EarthMover
                              Amazing work on the new version. You've created almost a patch method with really clean mesh results. THis is going to make a lot of people happy!
                              Content Creator at Skapeup
                                Daniel S
                                Thank you TIG!! Amazing!!!
                                This plugin deserves its own toolbar... what about adding one?
                                Daniel S
                                EEbyRails icons.zip
                                  Daniel S
                                  Thanks for the button pngs.
                                  Now I've got it working v2.1 will probably have a toolbar and I'm looking at consolidating the closing dialogs into a single [web]dialog... Might take a good few days as I am busy on other things right now...
                                    alpro
                                    Thanks TIG, I'm sure that this is gonna be one of my most used rubies. Awesome work.
                                    Mike
                                      Here's an EEbyRails new V2 example of making a 'flat-topped' sinuous roof barrel, with one end arched and the other angular, in two halves...EEbyRailsV2_FlatTop.png
                                      • Rich O BrienR Online
                                        This is way more than an improvement, this is exceptional scripting that pushing SU in a new direction
                                        Hats Off to you 👍
                                        • JClementsJ Offline
                                          JClements
                                          THANKS AGAIN!
                                          Question: Is there a way to control where the dialogs appear, or once the first appears allow the user to move it and all subsequent dialogs use the location of the first?
                                            @jclements said:
                                            THANKS AGAIN!
                                            You cannot affect the location or much to do with the basic UI dialogs... BUT you can with a 'web-dialog' - which is where I am heading with this... Look out for the next update...
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 19
                                            • 20
                                            • 7 / 20
