    [Plugin] Extrude Edges by Rails
    381 Posts 71 Posters 403.0k Views 71 Watching
    • X Offline
      xrok1
      oops, sorry i could help. 😳
      “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
      • TIGT Online
        xrok1 😉
        Your idea of being able to pick a profile and then pick just one rail is quite simple to do.
        For the next update I will add that option - you'll simply pick the profile and click on rail twice - if you pick another rail it works as now, if you pick the same rail again then it's assumed that it has a 'twin' at the other end of the profile and uses that... simplicity... 💭
        • utilerU Offline
          utiler
          TIG, probably a silly question, but what is the difference from this plugin and extrudebyedges?
          http://forums.sketchucation.com/viewtopic.php?f=180&t=20065&st=0&sk=t&sd=a&hilit=extrude+edges
          Is is simple that this script allows for more random meshes?
          Just Curious...
          • X Offline
            xrok1
            awsome.
            BTW, your plug is turning me into some kind of artsy fartsy... STOP IT! 😆
            • utilerU Offline
              utiler
              Thanks mate, clear as crystal..... 👍
              Just Curious...
              • mitcorbM Offline
                mitcorb
                @xrok1:
                for your excellent bowl and spork and "foon" model, did you use specific dimensions and scale? Or was this a free form experiment and the model elements proportioned by eye?
                I am preparing to use Extrude by Rails with dimensional or scale control and was wondering about this.
                Thanks, mitcorb
                • X Offline
                  xrok1
                  it was freeform 😆 but i can't see any reason it couldn't be dimensioned accurately if you wish to.
                  • majidM Offline
                    majid
                    WOW TIG !!!! this is great!! thank you...you are killing me slowly 😉 you ruby programmers are changing SU to a verrry different app. !!!thank you mate again
                    • TIGT Online
                      ExtrudeEdgesByEdges takes two groups - edges in them need not be continuous - and makes a mesh - it extrudes each edge in one set in the direction of the edges in the other - there is no 'followme' etc...
                      ExtrudeEdgesByRails is similar BUT it only works on curves. It takes a selected profile and makes a mesh from it along two selected rails [or with the forthcoming version one rail picked twice - making it similar in that usage to EEbyEdges]. The main difference is that at each pair of 'nodes' [vertices] in the two rails the profile is placed and rotated and then scaled to fit between the rails, giving a smoothly curving mesh surface: also the number of 'nodes' in each rail is equalized if the number of vertices in the two rails is uneven - now making the 'lofting' of two unequally segmented rails possible...
                      • mitcorbM Offline
                        mitcorb
                        TIG:
                        What are the possibilities of being able to orbit and inspect the initial results of the extrusion on rails while going through the checklist so that decisions can be made in the workflow? Does this make sense?
                        • TIGT Online
                          @mitcorb said:
                          TIG:
                          It's something that's not so easy to do... but I'll look at it - I currently have a version with most of the bugs ironed out - it'll be published soonest...
                          • mitcorbM Offline
                            mitcorb
                            Thanks, TIG:
                            You are a master.
                            I am currently experimenting and learning this excellent tool.
                              Cyberdactyl
                              Very nice Tig.
                              Works great in SU7. However, doesn't work SU6, at least for me.
                              • TIGT Online
                                Here is v1.1 http://forums.sketchucation.com/viewtopic.php?p=201286#p201286
                                It is now much more stable, with [most] glitches fixed with ordered points and bugsplats.
                                You can now also double-click on one rail and used it as both rails.
                                Rails that start / end at a common vertex are now allowed.
                                Mismatched segment numbers in the two rails are well accommodated - as are looped profiles and rails.
                                Debabelizer language translation are now added to menus and dialogs etc, with ExtrudeEdgesbyRailsEN-US.lingvo and ES/FR versions in the TIGtools folder.
                                Feedback please...
                                I've also updated the examples SKP here... http://forums.sketchucation.com/viewtopic.php?p=201457#p201457
                                • TIGT Online
                                  Here's an example SKP - updated for v1.1... ExtrudeEdgesByRailsExamples.skp
                                  • jeff hammondJ Offline
                                    jeff hammond
                                    just out of curiosity, i drew the same shapes using the same dimensions in SU with EdgesByRails then i did another in Rhino using Sweep 2rails.. i then brought the SU surface/mesh into rhino and overlayed the two.. here's what it looks like.
                                    (Sketchup = red... rhino =blue)
                                    click pic for larger
                                    the render mesh in rhino was set at a density of 100 making it about as close to the true nurbs surface that you can view on a computer.. all the vertices from SU edges by rails are right there where i'd hope they'd be.
                                    so yeah, use this plugin with confidence 😄
                                    dotdotdot
                                      ...and put Rhino in the garbage trash can 💚
                                        jeff hammond
                                        [haha frenchy]
                                        just in case that picture is confusing, here are the two surfaces separately..
                                        (rhino- blue... SU- red)
                                        click pic for bigger
                                        (sorry about the nasty quality of the pictures.. had to use screenshots because the output options in Rhino OS X (beta) aren't fully implemented yet.. i don't think my screenshots like red too much)
                                        ... and a render of the SU version after some joint_push_pull..
                                        dotdotdot
                                        • X Offline
                                          xrok1
                                          nice. thanks for implementing the single rail option. i will delete edges by edges plugin soon but...
                                          red is edges by rails result, blue is edges by edges result?? i think blue wins my vote on how things should work.
                                            jeff hammond
                                            as far as i can tell, both methods give the exact same results (3 tests and while one of the surfaces ended up in a strange location, it still matched the other)
                                            if you're talking about the triangulation then:
                                            with edgesBYedges, one of the options after running the script is 'triangulate faces?'
                                            with edgesBYrails, the second option that pops up is 'erase coplaner edges?'.. choose yes and the triangulation lines will go away (as long as they aren't necessary for the surfacing but since the geometry is the same with the two scripts for 1rail1edge, they'll end up identical if you choose yes to erase the coplanar edges)
                                            that said, maybe there's something i haven't tried that will make the two 1edge1rail methods produce different results..
                                            dotdotdot
                                            • 19
                                            • 20
                                            • 3 / 20
