    ๐Ÿ›ฃ๏ธ Road Profile Builder | Generate roads, curbs and pavements easily Download
    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.1m Views 73 Watching
    • Chris FullmerC Offline
      UPDATED!
      • Added rotation and twist capabilities
      • developed and added my menu items for donations and youtube
      • Added a no-scaling option
      Ok, there you have it. It now lets you rotate components easier for chain making. I updated the video on the main page, or see it here:
      http://www.youtube.com/watch?v=_ymYoEHiexg
      That shows how I would use it to make chains. Have fun!
      Chris
      All my Plugins I've written
      • simon le bonS Offline
        simon le bon
        @chris fullmer said:
        UPDATED!
        Hi Chris, ....!......
        Hi Jeff,
        Your Black and white chocolat Skeleton his highly... "eatable" ๐Ÿ˜†
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ClickDraw.jpg
        I thought it was not possible to make imbricated components with this Chris' tool...
        You show me I was wrong!
        I have tried to find your "how to".
        We just have to scale up or reajust with Move tool the component once it is distributed along the path.
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray029.jpg
        Scaled Up with FredoScale
        http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray030.jpg
        ๐Ÿ‘ ๐Ÿ˜‰ simon
          Can you use FredoScale to apply the same scaling to each component en masse?
            simon le bon
            Yes absolutely!
            You just need to enter one of the components, select all the geometry, and scale it ๐Ÿ˜‰
            http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer009th.jpg
            *s
              Speedy Chris! ๐Ÿ˜ฎ โ˜€ ๐Ÿ˜Ž
              Next add: colors? ๐Ÿ˜‰
                Ah! ofcourse - you open up the component! doh! I was thinking it scaled each instance. ๐Ÿ‘Š
                  c.plassais
                  Hi Chris,
                  Perfect as always
                  Christophe
                    Suggestion: a vertical rotation of each component in the same time between them
                    Another thing actualy plug works fine with path welded or not โ˜€
                    but not with curves "disconnected" : is that normal โ“
                    • plot-parisP Offline
                      plot-paris
                      fantastic plugin, Chris. there are going to be a lot of funny spine images in the gallery section now...
                      just two minor suggestion/question: when running your script it asks you whether start and end of the curve are right. then it lets you define the parameters. that means you will always have to perform at least two clicks, even if the curve direction is correct.
                      therefore my question: is it possible to go straight to the dialog box, while labeling start and end of the curve and having a check-box for 'reverse curve'?
                      ideally the 'start' and 'end' labels would dynamically change, when ticking/unticking the check-box.
                      and secondly: could you make the script remember former input during a SketchUp session? (except for the 'reverse curve' check-box of course). that might speed up workflow as well.
                      • E Offline
                        Ecuadorian
                        I certainly hope Chris and other Ruby geniuses get hired by the Google SketchUp team. SU might be a dead end if you want NURBS, but there's still a lot to be done with polygonal faces. ๐Ÿ‘
                        -Miguel Lescano
                          Click Draw
                          Hey Chris,
                          This is awesome! Thank you so much. I'm glad to see the PayPal link as well. You deserve it. I also love the crickets sound effects on your tutorials. Your obviously up late at night doing these. Thank you....
                          Jeff
                          Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                          • EscapeArtistE Offline
                            EscapeArtist
                            Chris, that is amazing. Thank you so much for the quick response to the ideas everyone posted.
                            Another fantastic plugin. Thanks!!
                              And you can after use the Shape Bender! ๐Ÿ˜‰
                              Not here ๐Ÿ˜’
                              http://forums.sketchucation.com/download/file.php?id=37213
                              Here yes, each link itself is now curvated after the general Shape bender ๐Ÿ˜‰
                              So a double curvature ๐Ÿ˜„
                              • Bob JamesB Offline
                                Bob James
                                Simply fantastic, Chris. Thank you so much for all your hard work: what would SU be without guys like you???
                                Again, thank you.
                                • utilerU Offline
                                  utiler
                                  [attachment=1:7pk9rqxb]<!-- ia1 -->vertical.jpg<!-- ia1 -->[/attachment:7pk9rqxb]
                                  [attachment=0:7pk9rqxb]<!-- ia0 -->yes_no.jpg<!-- ia0 -->[/attachment:7pk9rqxb]
                                  Another wish of mine, Pilou. see http://forums.sketchucation.com/viewtopic.php?f=180&t=19204
                                  The plugin in is getting sooooo close to a suggestion i had a while back; thanks again, Chris!!!!
                                  Would be great to have the option of rotation around all 3 axis and the order of rotation as well as with TIG's GROW plugin.....
                                    Yes! ๐Ÿ˜„
                                    Scripters are amazing people โ˜€
                                      leixing
                                      Thank you Chris
                                      itis wonderful!
                                      i find a little bug.if the compoents only have one face -- that means the componet is a 2d ojb ,then run the plu and nothing start. the ruby console said "Error: #<NoMethodError: undefined method `position' for nil:NilClass>"
                                      a very little bug ,just make a uimessage to tell people they must have a 3d components.
                                      thank you again!!
                                      • massimoM Offline
                                        massimo Moderator
                                        Thank you Chris. Tried this on SU6 free but i had some problems. The try was made with "scaling>uniform" and "0" rotation.
                                        • kenK Offline
                                          ken
                                          Chris, thanks for this plugin. I am almost on the way to making anchor chains of any length or curvature. However, I notice that on curves, it is still hard to get the links to stay the same size, as the different curves connected together will have different section lengths.
                                          So, I was wondering, how hard it would be to add a plugin called "Draw Line by Set Length". So I could pick this plugin, input the length of line I wish to draw. Say I inputted a line of 12" and all lines drawn would be 12" in length. So I could a draw a series of connected lines, they all would be 12" in length and curve to any direction. Than when I apply component stringer, my chain link's length would all be the same length along this many segmented line.
                                          Again, thanks for the plugin.
                                          Ken
                                            The major to do's - like loops and connected curves - are pretty much sorted in my ExtrudeEdgesToEdges... for the upcoming version I have borrowed some of the sorting edge-vertices code etc from Chris's script (which Chris probably borrowed from RickW [or my borrow of it?]!!!). Chris should then be able to transpose these fixes back into his script? My updated script will be out shortly...
                                            • 8
                                            • 9
                                            • 3 / 9
