    [Plugin] Component Stringer UPDATED May 23, 2013
    173 Posts 73 Posters 1.2m Views 73 Watching
    • C
      Click Draw
      Hi Ken,
      Like TIG said, make your component and then edit it and do what you like to alter the dimensions and shape and it will update as you do it. Very cool. You also have to make sure the axis is in the proper position on your component. Hope that makes sense. I'll be trying more shapes and posting here soon. Awesome script!
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • MALAISEM
        MALAISE
        Very efficient tool to create wood roofs, barrels ,boats and arches.
        Maybe Components axis should be shown
        PAM
        • JClementsJ
          JClements
          If you could also give user options to also scale along the component's other axes:
          (1) axes A-B and A-C, or (2) axis A-B, or (3) axis A-C, then you'd have something similar to a blend-along-path.
          And if it could then "skin" the sides (vertices) of the components, it would be equivalent to a Scaled-Extrusion Along a Path.Idea for another Script.png
          Idea for another Script.skp
          • W
            wolfy
            Another gem for the jewel box! Thanks Chris ☀
            • utilerU
              utiler
              Hi Chris, thanks for this great work!!! It is very close to something i have asked questions about in the past....
              Like Pilou, I think it would be great to see some rotation options at each segment. Also the suggestion of nil scaling would be nice too so the component is think dependent on segment length.....
              I haven't played with it yet but I can say now that it's a BOMB!!!!!!
              Just Curious...
                d12dozr
                @martinrinehart said:
                Blows me away, Chris. What was the inspiration?
                404 Not Found
                (forums.sketchucation.com)
                http://goo.gl/f7ooYh
                • Chris FullmerC
                  The rotation options are implemented here, so they will be in the next release. I also like John's ideas about scaling the components smaller. But that will take a lot of code writing so I would not count on seeing that soon. And I will not be using this tool to add a skin. That's very complex.
                  But I will say the rotation is working great and is perfect for chains. Nil scaling would be easy to implement. I'll put that in too. So I'll hopefully get this released within the next 24 hours.
                  Thanks for all the comments!
                  • Chris FullmerC
                    UPDATED!
                    • Added rotation and twist capabilities
                    • developed and added my menu items for donations and youtube
                    • Added a no-scaling option
                    Ok, there you have it. It now lets you rotate components easier for chain making. I updated the video on the main page, or see it here:
                    http://www.youtube.com/watch?v=_ymYoEHiexg
                    That shows how I would use it to make chains. Have fun!
                    • simon le bonS
                      simon le bon
                      @chris fullmer said:
                      UPDATED!
                      Hi Chris, ....!......
                      Hi Jeff,
                      Your Black and white chocolat Skeleton his highly... "eatable" 😆
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/ClickDraw.jpg
                      I thought it was not possible to make imbricated components with this Chris' tool...
                      You show me I was wrong!
                      I have tried to find your "how to".
                      We just have to scale up or reajust with Move tool the component once it is distributed along the path.
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray029.jpg
                      Scaled Up with FredoScale
                      http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/CopyArray030.jpg
                      👍 😉 simon
                        Can you use FredoScale to apply the same scaling to each component en masse?
                        • simon le bonS
                          simon le bon
                          Yes absolutely!
                          You just need to enter one of the components, select all the geometry, and scale it 😉
                          http://i274.photobucket.com/albums/jj245/Spendauballet/SketchUp/clfCompntStringer009th.jpg
                          *s
                            Speedy Chris! 😮 ☀ 😎
                            Next add: colors? 😉
                              Ah! ofcourse - you open up the component! doh! I was thinking it scaled each instance. 👊
                              • C
                                c.plassais
                                Hi Chris,
                                Perfect as always
                                Christophe
                                  Suggestion: a vertical rotation of each component in the same time between them
                                  Another thing actualy plug works fine with path welded or not ☀
                                  but not with curves "disconnected" : is that normal ❓
                                  • plot-parisP
                                    plot-paris
                                    fantastic plugin, Chris. there are going to be a lot of funny spine images in the gallery section now...
                                    just two minor suggestion/question: when running your script it asks you whether start and end of the curve are right. then it lets you define the parameters. that means you will always have to perform at least two clicks, even if the curve direction is correct.
                                    therefore my question: is it possible to go straight to the dialog box, while labeling start and end of the curve and having a check-box for 'reverse curve'?
                                    ideally the 'start' and 'end' labels would dynamically change, when ticking/unticking the check-box.
                                    and secondly: could you make the script remember former input during a SketchUp session? (except for the 'reverse curve' check-box of course). that might speed up workflow as well.
                                    • E
                                      Ecuadorian
                                      I certainly hope Chris and other Ruby geniuses get hired by the Google SketchUp team. SU might be a dead end if you want NURBS, but there's still a lot to be done with polygonal faces. 👍
                                      -Miguel Lescano
                                      • C
                                        Click Draw
                                        Hey Chris,
                                        This is awesome! Thank you so much. I'm glad to see the PayPal link as well. You deserve it. I also love the crickets sound effects on your tutorials. Your obviously up late at night doing these. Thank you....
                                        Jeff
                                        • EscapeArtistE
                                          EscapeArtist
                                          Chris, that is amazing. Thank you so much for the quick response to the ideas everyone posted.
                                          Another fantastic plugin. Thanks!!
                                            And you can after use the Shape Bender! 😉
                                            Not here 😒
                                            http://forums.sketchucation.com/download/file.php?id=37213
                                            Here yes, each link itself is now curvated after the general Shape bender 😉
                                            So a double curvature 😄
                                            • 3 / 9
