    Sandbox tools
    13 Posts 7 Posters 1.4k Views 7 Watching
    • K Offline
      katarina urbanska
      Hello,
      I would like to ask a question about sandbox tools.I have version7 and my problem is,that I cannot get the sandbox toolbar out on my work space.I have it only under draw or tools.But dont see it as other toolbars. Could anybody tell me what is the problem?
      Thanks so much,
      regards,
      Katarina
      • jeff hammondJ Offline
        jeff hammond
        [i'm on mac but i think this is the same way on windows]
        from the top menu bar..
        go to view
        then tool palettes
        click sandbox
        dotdotdot
          Click Windows>Preferences to open Dialog Box
          Select Extensions on the right
          Click check box for Sandbox
          Restart SketchUp
          Click View>Toolbars and check Sandbox
          The toolbar should appear
          This is for PC
            jeff hammond
            oh wait, that's the same on a mac too.. πŸ˜„
            i forgot about that part..ha
            (and, i can't remember if sanbox is turned on or off in the extensions by default?)
            dotdotdot
              I think it's off by default Jeff, but not 100%
                smhbrv
                Hi everyone.
                I want to write my problem on this title.
                I have a problem with Sandbox.
                I creted my land with your help. I want to put my building to the levels.
                I know, we use "Stamp" for putting building on levels. But I didn't write numeral value for determine the building how much deep or up.
                How can regulate that.?
                Thank you.
                  Push/Pull the building up/down. Perhaps leave it a little higher/lower than you intend it to be finally [depending on whether it is to be built up or cut in]... Afterwards you can always Select the building AND its flat stamped area (you can vary the offset of that flat area at the time of stamping by typing a new distance into the VCB) and by then using the Move Tool on this Selection: constrained vertically (blue) with Shift-key: then all connected geometry like 'embankments' will adjust their angle to suit...
                  • K Offline
                    katarina urbanska
                    Thank you Guys,
                    I have done it this way before-didnt work. When I wrote you...made it again-it worked
                    You are magic Guys.
                    Thanks a lot,
                    Have a Good one.
                    Kat
                      smhbrv
                      Thank you but I dont understand generally.
                      Can you explain with pictures... ?
                        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=116008
                        https://sketchup.google.com/support/bin/answer.py?hl=en&answer=46410
                        http://sketchup.google.com/support/bin/answer.py?answer=95061
                        http://sketchup.google.com/support/bin/answer.py?hl=en&answer=115432
                          mambo.harts.u
                          Is there a way that i can use scratch tool with irregular shape instead of the rectangular shape? say a star for example?
                            Once you drew your rectangular shape, you can draw any shape to intersect it with.
                            StarTIN.skp
                              mambo.harts.u
                              ohh... thanks a lot Gaieus!! This one's a great tool!
