    [Plugin] SmartPushPull v0.26 (05 nov)
    86 Posts 64 Posters 210.8k Views 65 Watching
    • boofredlayB Offline
      boofredlay
      Diego, this is what you want:
      http://forums.sketchucation.com/viewtopic.php?p=42783#p42783
        DIEGO-RODRIGUEZ
        I use the plugins, Joint Push Pull
        but not works as SmartPushPull v0.26
        idea for icons
          DIEGO-RODRIGUEZ
          can you add, pushpull for multiple faces?ยฟ
          maybe pressing> shift <
            monkeybss
            Very good! And in time, too.Thanks!
            • plot-parisP Offline
              plot-paris
              that would be great indeed. but I think a modifier key is unnecessary. simply apply the tool to more than one faces, if they have been pre-selected...
              • brookefoxB Offline
                brookefox
                I had occasion to use it a few times today and found it quite handy. As a matter of chance, I was grateful for the lingering edges as they made it easier to make progressive pulls in which intermediate sections could be readily deleted, as desired. Face colors did not track the original, which would have been preferred, and as, no doubt, you are aware.
                Thanks much for sharing.
                ~ Brooke
                • P Offline
                  Panga
                  Thanks a lot for this plugin !! Keep going !
                    a4chitect
                    thanks to all for leaving nice comments!
                    I read all suggestions and will definitely try to develop this plugin further. Please be patient...
                      Trev
                      spp.skpRe thomthom's problem, this can never be solved, as the corner causing the problem has 4 edges/faces not three, so the program does not know which edge/face should be top priority. Only happens if lines meet at corner, as even a couple of pixels on one edge/face is enough to ascertain direction.
                      Hopefully the file returned altered will point this out better, one item prioritises the green face, the other the red. When the green is used, as seems to be happening when I tried it, you need to physically add a line to complete the edges/faces as shown in the blue faces in the diagram.
                      Hope this helps clear this up.
                      Trev. (total newbie)
                        Trev
                        By the way, forgot to say thanks for this great plugin, a4chitect.
                        • ken28875K Offline
                          ken28875
                          Awesome plugin, a4chitect.
                          Thank you very much!
                          Follow Your Dreams.
                            liveevil
                            i like it....
                              romain210
                              that's realy cool
                              thanks a lot
                                donpter
                                thank you for your application!
                                  Use it and it's very brilliant ๐Ÿ˜Ž
                                  but a little remark ๐Ÿ˜’
                                  you call it "Smart Push Pull" but seems it's only "Smart Pull" or I miss something? โ“
                                    plot-paris
                                    well spottet, Pilou ๐Ÿ˜„
                                    • X Offline
                                      xrok1
                                      is it possible to not leave internal faces with this plug??
                                      โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                                        I finally got around to use this plugin. Very nice.
                                        Are you still developing it?
                                        I noticed a couple of things:
                                        1. It does not draw the input points
                                        2. It does not invalidate the view when the tool is activated
                                          caleb_barclay
                                          I love this script. It is perfect for roofs. I was wondering if there was anyway to enable it to "Snap" to a reference point. I have CAD drawings that I would like the extrusion to snap to.
                                            plot-paris
                                            @thomthom said:
                                            Are you still developing it?d
                                            indeed, a4chitect. do you intend to do some further work on this plugin?
                                            • 3 / 5
