    [Plugin] SmartPushPull v0.26 (05 nov)
    86 Posts 64 Posters 216.6k Views 65 Watching
      serena
      • boofredlayB
        boofredlay
        Diego, this is what you want:
        http://forums.sketchucation.com/viewtopic.php?p=42783#p42783
          DIEGO-RODRIGUEZ
          I use the plugins, Joint Push Pull
          but not works as SmartPushPull v0.26
          idea for icons
            DIEGO-RODRIGUEZ
            can you add, pushpull for multiple faces?ยฟ
            maybe pressing> shift <
              monkeybss
              Very good! And in time, too.Thanks!
              • plot-parisP
                plot-paris
                that would be great indeed. but I think a modifier key is unnecessary. simply apply the tool to more than one faces, if they have been pre-selected...
                • brookefoxB
                  brookefox
                  I had occasion to use it a few times today and found it quite handy. As a matter of chance, I was grateful for the lingering edges as they made it easier to make progressive pulls in which intermediate sections could be readily deleted, as desired. Face colors did not track the original, which would have been preferred, and as, no doubt, you are aware.
                  Thanks much for sharing.
                  ~ Brooke
                  • P
                    Panga
                    Thanks a lot for this plugin !! Keep going !
                      a4chitect
                      thanks to all for leaving nice comments!
                      I read all suggestions and will definitely try to develop this plugin further. Please be patient...
                      • T
                        Trev
                        spp.skpRe thomthom's problem, this can never be solved, as the corner causing the problem has 4 edges/faces not three, so the program does not know which edge/face should be top priority. Only happens if lines meet at corner, as even a couple of pixels on one edge/face is enough to ascertain direction.
                        Hopefully the file returned altered will point this out better, one item prioritises the green face, the other the red. When the green is used, as seems to be happening when I tried it, you need to physically add a line to complete the edges/faces as shown in the blue faces in the diagram.
                        Hope this helps clear this up.
                        Trev. (total newbie)
                        • T
                          Trev
                          By the way, forgot to say thanks for this great plugin, a4chitect.
                          • ken28875K
                            ken28875
                            Awesome plugin, a4chitect.
                            Thank you very much!
                            Follow Your Dreams.
                            • L
                              liveevil
                              i like it....
                                romain210
                                that's realy cool
                                thanks a lot
                                  donpter
                                  thank you for your application!
                                    Use it and it's very brilliant ๐Ÿ˜Ž
                                    but a little remark ๐Ÿ˜’
                                    you call it "Smart Push Pull" but seems it's only "Smart Pull" or I miss something? โ“
                                    • plot-parisP
                                      plot-paris
                                      well spottet, Pilou ๐Ÿ˜„
                                      • X
                                        xrok1
                                        is it possible to not leave internal faces with this plug??
                                        โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                                          I finally got around to use this plugin. Very nice.
                                          Are you still developing it?
                                          I noticed a couple of things:
                                          1. It does not draw the input points
                                          2. It does not invalidate the view when the tool is activated
                                          • C
                                            caleb_barclay
                                            I love this script. It is perfect for roofs. I was wondering if there was anyway to enable it to "Snap" to a reference point. I have CAD drawings that I would like the extrusion to snap to.
                                            • 3 / 5
