    [Plugin] SmartPushPull v0.26 (05 nov)
    86 Posts 64 Posters 217.3k Views 65 Watching
    • P
      push
      thank you!
        mics_54
        very cool, thanks!
          serena
          • boofredlayB
            boofredlay
            Diego, this is what you want:
            http://forums.sketchucation.com/viewtopic.php?p=42783#p42783
              DIEGO-RODRIGUEZ
              I use the plugins, Joint Push Pull
              but not works as SmartPushPull v0.26
              idea for icons
                DIEGO-RODRIGUEZ
                can you add, pushpull for multiple faces?ยฟ
                maybe pressing> shift <
                  monkeybss
                  Very good! And in time, too.Thanks!
                  • plot-parisP
                    plot-paris
                    that would be great indeed. but I think a modifier key is unnecessary. simply apply the tool to more than one faces, if they have been pre-selected...
                    • brookefoxB
                      brookefox
                      I had occasion to use it a few times today and found it quite handy. As a matter of chance, I was grateful for the lingering edges as they made it easier to make progressive pulls in which intermediate sections could be readily deleted, as desired. Face colors did not track the original, which would have been preferred, and as, no doubt, you are aware.
                      Thanks much for sharing.
                      ~ Brooke
                      • P
                        Panga
                        Thanks a lot for this plugin !! Keep going !
                          a4chitect
                          thanks to all for leaving nice comments!
                          I read all suggestions and will definitely try to develop this plugin further. Please be patient...
                          • T
                            Trev
                            spp.skpRe thomthom's problem, this can never be solved, as the corner causing the problem has 4 edges/faces not three, so the program does not know which edge/face should be top priority. Only happens if lines meet at corner, as even a couple of pixels on one edge/face is enough to ascertain direction.
                            Hopefully the file returned altered will point this out better, one item prioritises the green face, the other the red. When the green is used, as seems to be happening when I tried it, you need to physically add a line to complete the edges/faces as shown in the blue faces in the diagram.
                            Hope this helps clear this up.
                            Trev. (total newbie)
                            • T
                              Trev
                              By the way, forgot to say thanks for this great plugin, a4chitect.
                              • ken28875K
                                ken28875
                                Awesome plugin, a4chitect.
                                Thank you very much!
                                Follow Your Dreams.
                                • L
                                  liveevil
                                  i like it....
                                    romain210
                                    that's realy cool
                                    thanks a lot
                                      donpter
                                      thank you for your application!
                                        Use it and it's very brilliant ๐Ÿ˜Ž
                                        but a little remark ๐Ÿ˜’
                                        you call it "Smart Push Pull" but seems it's only "Smart Pull" or I miss something? โ“
                                        • plot-parisP
                                          plot-paris
                                          well spottet, Pilou ๐Ÿ˜„
                                          • X
                                            xrok1
                                            is it possible to not leave internal faces with this plug??
                                            โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                                            • 3 / 5
