    [Plugin] SmartPushPull v0.26 (05 nov)
    86 Posts 64 Posters 210.2k Views 65 Watching
      DIEGO-RODRIGUEZ
      I use the plugins, Joint Push Pull
      but not works as SmartPushPull v0.26
      idea for icons
        DIEGO-RODRIGUEZ
        can you add, pushpull for multiple faces?ΒΏ
        maybe pressing> shift <
          monkeybss
          Very good! And in time, too.Thanks!
          • plot-parisP Offline
            plot-paris
            that would be great indeed. but I think a modifier key is unnecessary. simply apply the tool to more than one faces, if they have been pre-selected...
            • brookefoxB Offline
              brookefox
              I had occasion to use it a few times today and found it quite handy. As a matter of chance, I was grateful for the lingering edges as they made it easier to make progressive pulls in which intermediate sections could be readily deleted, as desired. Face colors did not track the original, which would have been preferred, and as, no doubt, you are aware.
              Thanks much for sharing.
              ~ Brooke
                Panga
                Thanks a lot for this plugin !! Keep going !
                  a4chitect
                  thanks to all for leaving nice comments!
                  I read all suggestions and will definitely try to develop this plugin further. Please be patient...
                    Trev
                    spp.skpRe thomthom's problem, this can never be solved, as the corner causing the problem has 4 edges/faces not three, so the program does not know which edge/face should be top priority. Only happens if lines meet at corner, as even a couple of pixels on one edge/face is enough to ascertain direction.
                    Hopefully the file returned altered will point this out better, one item prioritises the green face, the other the red. When the green is used, as seems to be happening when I tried it, you need to physically add a line to complete the edges/faces as shown in the blue faces in the diagram.
                    Hope this helps clear this up.
                    Trev. (total newbie)
                      Trev
                      By the way, forgot to say thanks for this great plugin, a4chitect.
                      • ken28875K Offline
                        ken28875
                        Awesome plugin, a4chitect.
                        Thank you very much!
                        Follow Your Dreams.
                          liveevil
                          i like it....
                            romain210
                            that's realy cool
                            thanks a lot
                              donpter
                              thank you for your application!
                                Use it and it's very brilliant 😎
                                but a little remark πŸ˜’
                                you call it "Smart Push Pull" but seems it's only "Smart Pull" or I miss something? ❓
                                  plot-paris
                                  well spottet, Pilou πŸ˜„
                                  • X Offline
                                    xrok1
                                    is it possible to not leave internal faces with this plug??
                                      I finally got around to use this plugin. Very nice.
                                      Are you still developing it?
                                      I noticed a couple of things:
                                      1. It does not draw the input points
                                      2. It does not invalidate the view when the tool is activated
                                        caleb_barclay
                                        I love this script. It is perfect for roofs. I was wondering if there was anyway to enable it to "Snap" to a reference point. I have CAD drawings that I would like the extrusion to snap to.
                                          plot-paris
                                          @thomthom said:
                                          Are you still developing it?d
                                          indeed, a4chitect. do you intend to do some further work on this plugin?
                                          • majidM Offline
                                            majid
                                            woww. thanx mate.... really smart (you and the plugin, both πŸ˜‰ ) πŸ‘
                                            • 3 / 5
