    Quality of exported jpeg
    10 Posts 8 Posters 1.1k Views 8 Watching
    • Q
      qwerter
      Hello,
      I'm working on a scene in sketchup but I'm running into a problem.
      I need a 2500x1116 jpeg so tried exporting it, as you can see the lines are ugly.
      A printscreen from the same scene look beter but is to small.
      What am I doing wrong?, I've tried all of the options with exporting.
      Exported
      Printscreen
      • P
        PRSS
        Turn on antialiasing in the export options
        With best regards
        PRSS
        • soloS
          solo
          Try exporting at double or triple the intended size and then resize in post edit.
          http://www.solos-art.com
          • thomthomT
            With best regards
            PRSS
            I find the AA poor and very slow. I do what Solo do, export x2 or x3 and size back down in Photoshop.
            • N
              NewOne
              Something is wrong with your gravity settings... I see things floating around there 😕
              • E
                Ecuadorian
                Or scale it with the free Pliska Image Resizer, the dead-easy way to scale lots of images for posting on forums and sending to clients:
                http://download.cnet.com/PLiska-Image-Resizer/3000-2192_4-10411174.html
                -Miguel Lescano
                • brodieB
                  brodie
                  The basic issue is that a line is always exported at 1 pixel. So if your whole image is 50 pixels wide a vertical line will be 1/50th of your total image. But if you're image is 500 pixels wide it will be only 1/500th of your total image (ie. thinner).
                  So when you export at a larger size the lines will be thinner in relation to the rest of your image.
                  -Brodie
                  • Q
                    qwerter
                    Ok, thanks to all
                    • thomthomT
                      -Brodie
                      Yea, that is a problem some times. Option is to set a style with thick edges.
                      • K
                        Kent L
                        The BEST solution is to export from Layout7. Its renders are far better than from Sketchup directly and you can specify a line weight without having to use custom styles.
