    [Plugin] CleanUp
    974 Posts 217 Posters 966.7k Views 217 Watching
      Presumably there are many internal partition.floor faces showing where the horizontal divisions show...
      You need to use a tool like 'SolidSolver', which tries to remove these and make the geometry a manifold...
      Really you are NOT trying to 'CleanUp' the SKP: rather, you are trying to make it into a 'Solid' - which is a different issue...
        @yildirimyazgan said:
        they dont dissapear after the explosion Thus the script sees them as a "corner defining" edge.
        Where are these extruded triangles groups/components originally? Which you exploded?
        If that is the case - they would be solids and I'd recommend you use Solid Tools to merge them all. That should take care of the internal faces which prevents the edges from being cleaned up.
          crizilla
          thanks for this. However that would be awesome if you added a "merge vertices" feature. Whenever I import into maya, I have to merge all the vertices. I get tons of overlapping. Shouldn't be that difficult, right? You did it for faces πŸ˜„
            Got a sample model?
              crizilla
              @thomthom said:
              Got a sample model?
              pretty much any model i do that I bring into Maya it does it. Select a corner vertex and move it, you'll see it will leave a duplicated one there instead of moving all the polygons that you think is connected to that vertex. It's not a big deal. Just throwing it out there.
                Into Maya? I though it was when you imported a Maya model into SketchUp... ?
                In which case it'd be interesting for me to see a sample model - I don't have Maya.
                • G Offline
                  geonsx
                  Hi !
                  Quick question !
                  Is there a version for Mac user's ?
                  George
                    Same plugin for both PC and Mac.
                    Just curious. What makes you think there's a separate version for Mac?
                      Ditto. Once in a while people ask this. So I wonder if it's something in my description that makes people think it's Window only?
                      • G Offline
                        geonsx
                        Hi !
                        Thank you for the quick answer.
                        In the website where I have seen this plug in, the demo was for windows, and their was no mention of a Mac version.
                        But I kind of knew it was for both versions. I install it and it worked.
                        Now I have to get used to it, because it removes my windows glass materials finish.
                        So I guess, a lot of trials and errors ahead...
                        Thank you very much.
                        George
                          Take not of the checkboxes that says Ignore Materials and Ignore Normals. I've observed that some users check every checkbox without actually being aware of what they do.
                          Do you perhaps have a before and after screenshot?
                          • O Offline
                            OmarSun
                            Hi thomthom.
                            CleanUp Version: 3.2.0; April 24, 2013, donΒ΄t show the setup window, work fine "Clean with last setting" option.
                            and erase me the VrayDomeLight in the escene.
                            TTCleanUp 3.2.0
                            TTLib 2.8.3
                            Sketchup 2013 Pro Spanish version
                            Ruby Console:
                            Warning! Theme 'window.html' could not be loaded. File not found.
                            Error: #<RuntimeError: Could not load TT::Window theme: window.html>
                            C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:525:in get_theme_path' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:538:in build_html'
                            C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:473:in show_window' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/toolwindow.rb:25:in show_window'
                            C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/modal_wrapper.rb:38:in activate' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/modal_wrapper.rb:110:in push_tool'
                            C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/modal_wrapper.rb:110:in show' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/inputbox.rb:290:in prompt'
                            C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/tt_cleanup/core.rb:408:in `show_cleanup_ui'
                            C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/tt_cleanup/core.rb:226
                            Thanks, Great Job.
                            PD. Sorry my english
                              That's strange. I'll look into it. Thanks for the full error message.
                              I'm sorry, but what's with the VrayDomeLight?
                              Oh - it's erasing the dome light in the model - because the dome light is just edges, right?
                                C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:525:in `get_theme_path'
                                Can you verify this file exists: "C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/webdialog/window.html" ?
                                Did you get any error messages when you installed TT_Lib?
                                • O Offline
                                  OmarSun
                                  No error messages when instaling TTlib from extensiΓ³n warehouse
                                  and i not found "webdialog" folder
                                  http://i1275.photobucket.com/albums/y456/omarsun/Captura1_zps5b6001ba.jpg
                                  please, sorry my english
                                  %(#8000BF)[EDIT
                                  I reinstall TT_lib 2.8.3 with Sketchucation Plugin Store, and Cleanup 3.2.0 work fine now] πŸ‘
                                  Tanks.
                                    yay! πŸ˜„
                                      mk_mk
                                      hy
                                      I am using your plugin for a long time now and i realy love it. thank u!
                                      but now i have updated to 2013 pro and there i cant find a plugin section in the topmenue. where can i now find the button for your plugin?
                                      thank u
                                      Markus
                                        Nothing has changed - so I'm not sure what it might be. How did you install it in SU2013? Did you copy it or did you install from the Extension Warehouse or SketchUcation's Plugin store?
                                        Did you also ensure to install TT_Lib2?
                                          ruslan007
                                          hi:)
                                          I positioned the cleanup plugin in the plugins folder, but can not see the plug on my view port .not in tools or plugins:(
                                          can you help me to install it properly ?
                                          • massimoM Offline
                                            massimo Moderator
                                            Did you also installed the TTlib2 as clearly stated under "requirements" in the very first post of the thread?
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 48
                                            • 49
                                            • 39 / 49
