    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      Same plugin for both PC and Mac.
      Just curious. What makes you think there's a separate version for Mac?
        Ditto. Once in a while people ask this. So I wonder if it's something in my description that makes people think it's Window only?
        • G
          geonsx
          Hi !
          Thank you for the quick answer.
          In the website where I have seen this plug in, the demo was for windows, and their was no mention of a Mac version.
          But I kind of knew it was for both versions. I install it and it worked.
          Now I have to get used to it, because it removes my windows glass materials finish.
          So I guess, a lot of trials and errors ahead...
          Thank you very much.
          George
            Take not of the checkboxes that says Ignore Materials and Ignore Normals. I've observed that some users check every checkbox without actually being aware of what they do.
            Do you perhaps have a before and after screenshot?
            • O
              OmarSun
              Hi thomthom.
              CleanUp Version: 3.2.0; April 24, 2013, don´t show the setup window, work fine "Clean with last setting" option.
              and erase me the VrayDomeLight in the escene.
              TTCleanUp 3.2.0
              TTLib 2.8.3
              Sketchup 2013 Pro Spanish version
              Ruby Console:
              Warning! Theme 'window.html' could not be loaded. File not found.
              Error: #<RuntimeError: Could not load TT::Window theme: window.html>
              C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:525:in get_theme_path' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:538:in build_html'
              C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:473:in show_window' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/toolwindow.rb:25:in show_window'
              C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/modal_wrapper.rb:38:in activate' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/modal_wrapper.rb:110:in push_tool'
              C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/modal_wrapper.rb:110:in show' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/inputbox.rb:290:in prompt'
              C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/tt_cleanup/core.rb:408:in `show_cleanup_ui'
              C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/tt_cleanup/core.rb:226
              Thanks, Great Job.
              PD. Sorry my english
                That's strange. I'll look into it. Thanks for the full error message.
                I'm sorry, but what's with the VrayDomeLight?
                Oh - it's erasing the dome light in the model - because the dome light is just edges, right?
                  C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:525:in `get_theme_path'
                  Can you verify this file exists: "C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/webdialog/window.html" ?
                  Did you get any error messages when you installed TT_Lib?
                  • O
                    OmarSun
                    No error messages when instaling TTlib from extensión warehouse
                    and i not found "webdialog" folder
                    http://i1275.photobucket.com/albums/y456/omarsun/Captura1_zps5b6001ba.jpg
                    please, sorry my english
                    %(#8000BF)[EDIT
                    I reinstall TT_lib 2.8.3 with Sketchucation Plugin Store, and Cleanup 3.2.0 work fine now] 👍
                    Tanks.
                      yay! 😄
                        mk_mk
                        hy
                        I am using your plugin for a long time now and i realy love it. thank u!
                        but now i have updated to 2013 pro and there i cant find a plugin section in the topmenue. where can i now find the button for your plugin?
                        thank u
                        Markus
                          Nothing has changed - so I'm not sure what it might be. How did you install it in SU2013? Did you copy it or did you install from the Extension Warehouse or SketchUcation's Plugin store?
                          Did you also ensure to install TT_Lib2?
                            ruslan007
                            hi:)
                            I positioned the cleanup plugin in the plugins folder, but can not see the plug on my view port .not in tools or plugins:(
                            can you help me to install it properly ?
                            • massimoM
                              massimo Moderator
                              Did you also installed the TTlib2 as clearly stated under "requirements" in the very first post of the thread?
                                ruslan007
                                hi MAssimo!:)
                                i tried to install'but the problem is,i cant see on my view port in system preferences-- extensions the install preferences tab
                                is there another way to install the " tt installer?
                                thanks again
                                • massimoM
                                  massimo Moderator
                                  Then you need to upgrade at least to the latest version of SU8.
                                  You can rename a .rbz file into .zip then extract it an put the content of the folder in your plugins folder, or you can use the great Sketchucation tools.
                                  • tt_suT
                                    tt_su
                                    Definitely upgrade your SketchUp version.
                                    • F
                                      flyashy
                                      While this is a most well-worked plugin, I have a suggestion towards improving it's usability.
                                      A lot of times I use an autocad file for reference on a hidden layer to be switched on or off as per need. The plugin treats the dwg lines as lonely edges and erases them. A lot of times I realize that only after a long while when I switch on the layer for reference and find the dwg lines erased. To import and align the dwg again is doable but a bit of bother.
                                      The work around I use is to copy the dwg (usually as a group) before clean up operation and paste in place afterwards.
                                      I was wondering if the plugin can be made to ignore locked objects as an option. This way, if need be, one could retain 'unclean' elements in the model simply by locking them and then running cleanup while choosing 'ignore locked objects'.
                                      Alternately it could be made to ignore hidden layers or something like that.
                                      I don't know much about ruby and so don't know if something like that is possible, but I'm sure it would be a useful improvement.
                                      Cheers,
                                      flyashy
                                      • tt_suT
                                        tt_su
                                        Yea, I have it on the To Do list to make this plugin respect locked groups/components. I've done the same thing as you when working with imported DWG drawings.
                                        • G
                                          gpg
                                          Excellent!
                                          Downloaded, selected an imported 3d and ran the tool to merge faces.
                                          Instantly the majority of triangulated faces became proper faces.
                                          I had to blink a few times before I relised what had happened!
                                          Saved me an hour of clicking...
                                          For some reason 1 part of the model did not cleanup - otherwise perfect.
                                          Thank-you for your hard work!
                                          GPG
                                          • tt_suT
                                            tt_su
                                            If some edges doesn't erase then it would be either because the connected faces isn't 100% coplanar, or the edge has more than two faces connected.
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 48
                                            • 49
                                            • 39 / 49
