    [Plugin] CleanUp
    974 Posts 217 Posters 1.3m Views 217 Watching
      @geonsx said:
      Now I have to get used to it, because it removes my windows glass materials finish.
      Take not of the checkboxes that says Ignore Materials and Ignore Normals. I've observed that some users check every checkbox without actually being aware of what they do.
      Do you perhaps have a before and after screenshot?
      • O
        OmarSun
        Hi thomthom.
        CleanUp Version: 3.2.0; April 24, 2013, don´t show the setup window, work fine "Clean with last setting" option.
        and erase me the VrayDomeLight in the escene.
        TTCleanUp 3.2.0
        TTLib 2.8.3
        Sketchup 2013 Pro Spanish version
        Ruby Console:
        Warning! Theme 'window.html' could not be loaded. File not found.
        Error: #<RuntimeError: Could not load TT::Window theme: window.html>
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:525:in get_theme_path' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:538:in build_html'
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:473:in show_window' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/toolwindow.rb:25:in show_window'
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/modal_wrapper.rb:38:in activate' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/modal_wrapper.rb:110:in push_tool'
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/modal_wrapper.rb:110:in show' C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/inputbox.rb:290:in prompt'
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/tt_cleanup/core.rb:408:in `show_cleanup_ui'
        C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/tt_cleanup/core.rb:226
        Thanks, Great Job.
        PD. Sorry my english
          That's strange. I'll look into it. Thanks for the full error message.
          I'm sorry, but what's with the VrayDomeLight?
          Oh - it's erasing the dome light in the model - because the dome light is just edges, right?
            C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/window.rb:525:in `get_theme_path'
            Can you verify this file exists: "C:/Program Files (x86)/SketchUp/SketchUp 2013/Plugins/TT_Lib2/webdialog/window.html" ?
            Did you get any error messages when you installed TT_Lib?
            • O
              OmarSun
              No error messages when instaling TTlib from extensión warehouse
              and i not found "webdialog" folder
              http://i1275.photobucket.com/albums/y456/omarsun/Captura1_zps5b6001ba.jpg
              please, sorry my english
              %(#8000BF)[EDIT
              I reinstall TT_lib 2.8.3 with Sketchucation Plugin Store, and Cleanup 3.2.0 work fine now] 👍
              Tanks.
                yay! 😄
                  mk_mk
                  hy
                  I am using your plugin for a long time now and i realy love it. thank u!
                  but now i have updated to 2013 pro and there i cant find a plugin section in the topmenue. where can i now find the button for your plugin?
                  thank u
                  Markus
                    Nothing has changed - so I'm not sure what it might be. How did you install it in SU2013? Did you copy it or did you install from the Extension Warehouse or SketchUcation's Plugin store?
                    Did you also ensure to install TT_Lib2?
                      ruslan007
                      hi:)
                      I positioned the cleanup plugin in the plugins folder, but can not see the plug on my view port .not in tools or plugins:(
                      can you help me to install it properly ?
                      • massimoM
                        massimo Moderator
                        Did you also installed the TTlib2 as clearly stated under "requirements" in the very first post of the thread?
                          ruslan007
                          hi MAssimo!:)
                          i tried to install'but the problem is,i cant see on my view port in system preferences-- extensions the install preferences tab
                          is there another way to install the " tt installer?
                          thanks again
                          • massimoM
                            massimo Moderator
                            Then you need to upgrade at least to the latest version of SU8.
                            You can rename a .rbz file into .zip then extract it an put the content of the folder in your plugins folder, or you can use the great Sketchucation tools.
                            • tt_suT
                              tt_su
                              Definitely upgrade your SketchUp version.
                              • F
                                flyashy
                                While this is a most well-worked plugin, I have a suggestion towards improving it's usability.
                                A lot of times I use an autocad file for reference on a hidden layer to be switched on or off as per need. The plugin treats the dwg lines as lonely edges and erases them. A lot of times I realize that only after a long while when I switch on the layer for reference and find the dwg lines erased. To import and align the dwg again is doable but a bit of bother.
                                The work around I use is to copy the dwg (usually as a group) before clean up operation and paste in place afterwards.
                                I was wondering if the plugin can be made to ignore locked objects as an option. This way, if need be, one could retain 'unclean' elements in the model simply by locking them and then running cleanup while choosing 'ignore locked objects'.
                                Alternately it could be made to ignore hidden layers or something like that.
                                I don't know much about ruby and so don't know if something like that is possible, but I'm sure it would be a useful improvement.
                                Cheers,
                                flyashy
                                • tt_suT
                                  tt_su
                                  Yea, I have it on the To Do list to make this plugin respect locked groups/components. I've done the same thing as you when working with imported DWG drawings.
                                  • G
                                    gpg
                                    Excellent!
                                    Downloaded, selected an imported 3d and ran the tool to merge faces.
                                    Instantly the majority of triangulated faces became proper faces.
                                    I had to blink a few times before I relised what had happened!
                                    Saved me an hour of clicking...
                                    For some reason 1 part of the model did not cleanup - otherwise perfect.
                                    Thank-you for your hard work!
                                    GPG
                                    • tt_suT
                                      tt_su
                                      If some edges doesn't erase then it would be either because the connected faces isn't 100% coplanar, or the edge has more than two faces connected.
                                      • K
                                        korre
                                        My deepest respect! Thx a Billion!
                                          jumpjack
                                          Thsi plugin looks interesting, but is there a method to stop processing if it takes too long?
                                          • tt_suT
                                            tt_su
                                            Afraid not. 😞
                                            • 37
                                            • 38
                                            • 39
                                            • 40
                                            • 41
                                            • 48
                                            • 49
                                            • 39 / 49
