    [Plugin] CleanUp
    974 Posts 217 Posters 967.2k Views 217 Watching
    • john2J Offline
      john2
      so when do we see this "don't delete the lockd objects version?" πŸ˜‰
      • kingsiK Offline
        kingsi
        Already said thanks for this plugin before, but felt had to say Tusen Takk!! when it just cleaned out 3million lines lol. Bloody genius
        Noobtastic
          πŸ‘ πŸ˜„
          • K Offline
            kandehalux
            dang it....sorry for bothering, love your plugins!
            now a problem occured with the installation of cleanup:
            the TT_Lib2 is in the Plugins folder, the cleanup.rb is in the plugins folder.
            but when starting up sketchup i get this message:
            Error Loading File tt_cleanup.rb
            uninitialized constant TT::GUI
            in the forum i found suggestions with missing dlls on various windows, but no change. other plugins work fine.
            I'm on Win7 x64 using Sketchup 8.0.3117
            in addition i have to say,
            previously i resetted my pc and of course installed sketchup. before that, cleanup worked like a charme. i still have a backup of the old installation, so i tried using the older version of cleanup and ttlib, but i got the same message.
            any idea?
              Sounds like TT_LIb2 isn't installed correctly, there should be a TT_Lib2 folder with lots of .rb files in it.
              I made a small utility that makes it easier to install plugins correctly: http://forums.sketchucation.com/viewtopic.php?t=42315
              I recommend you update to the latest Maintenance Release 3 - it includes several bugfixes etc.
              • K Offline
                kandehalux
                alright, so i updated to the m3 release v8.0.14346 (didnt really notice that it was an actual update due to the version number). the plugins are installed correctly.
                in the meantime i found out, that it must have something to do with the template-loader of sketchup. because every plugin loads correctly, when i start directly with an skp-file (even with original template-skps). if i start sketchup without an skp, half of the plugins dont load.
                  Try running Sketchup 'As Admin' and see if that works - sounds like your permissions are limited - show Bill Gates who's boss ! Windows can treat you like a moron! Of course I'm not suggesting that you are not a moron πŸ˜• πŸ˜‰ Fix your security settings - become an Admin at least...
                  • K Offline
                    kandehalux
                    ...yea, and since windows 7 like a real super moron. being admin and thinking being admin are different chapters in the holy book of "How to suprise with even more stupid ideas of programming".
                    Unfortunately it didn't help...does the same when i start sketchup as admin...maybe i have to install as admin....gosh...i am the admin! but it doesnt matter, can live with that!
                    thanks!
                      mac1
                      1. "previously i reset my pc and of course installed sketchup.' This appears to be the failure point?
                        Have you tried removing the clean-up plugin and see if rest load?
                        Can you regress to a restore point before 1 above?
                        Have you tried making a new template and reloading?
                        If you use the native plugins installed with SU8 M3 does loading work ok?
                        Just some wild TS thoughts:)
                        angeliapayne
                        no such file to load -- TT_Lib2/core.rb
                        I have downloaded the latest version of SU (8.0.14346) and I have also downloaded and use your Plugin Installer and I still get the error. Any thoughts?
                        I've also tried running as Admin and no diff.
                        Thanks for keeping this post aliver - super excited about the potential of this script!
                          Looks like you didn't get the required TT_Lib2 file. Go back to the first post and read the section called Requirements. Download and install the TT-lib2 file.
                          • I Offline
                            ivreich
                            Purge Unused > Purge Unused Layers / Purge Unused Materials / Purge Unused Styles
                            Hi Thom Thom
                            Is it possible to have the "purge unused" function separated into purge unused layers, purge unused materials and purge unused styles?
                            This would be useful for maintaining the structure of material palettes/ layer templates in models that require separate management of these hierarchies.
                            Cheers
                            Joel
                              I already wrote that years ago... http://forums.sketchucation.com/viewtopic.php?p=82559#p82559
                              • panixiaP Offline
                                panixia
                                oh my god how can i miss this one till now!!! 😲
                                cleanin'up the ultra-crappy archicad model of the boss and it works like magic!
                                thank youu!!!
                                • john2J Offline
                                  john2
                                  when are we gonna have a feature that ignores locked groups e.g. autocad imported drawings? πŸ˜„
                                  • Chris FullmerC Offline
                                    This one has come in super handy today Thom, thanks!
                                    All my Plugins I've written
                                    • I Offline
                                      IronKrzysiek
                                      Hey all.
                                      It was my favorite plugin but for about few weeks it's not working...i just instaled in this time sketchup BIM plugin but it makes that cleaner was crashing...so I decided to delate SU BIM and reinstal cleaner...now it's just not working...just nothing happen with the model...i'm so confused...can somebody help or somebody had same problem??
                                      Regards.
                                        Did you get rid of all of the BIM plugin. It has been known to cause problems and perhaps you've missed removing a file. Or is it possible when you reinstalled CleanUp you didn't install it correctly? A screenshot of the Plugins folder would be useful.
                                          mac1
                                          Make sure the version of cleaner you reinstalled has the Lib to support it so double check ThomThoms install instruction.
                                          • pbacotP Offline
                                            When I choose Clean with last settings from the Menu, FredO's ThruPaint comes up. Any ideas how to stop that, other than uninstalling ThruPaint?
                                            Peter
                                            And, if I haven't said before, this is a great tool. Use it all the time--not just for messes but to save tons of work while drawing!
                                            [Edit: I figured out that it is related to a setting in ThruPaint- "automatically activate Thrupaint when invoking the SU native Paint Tool".
                                            None of the CleanUp individual Menu selections do this. Only when running Clean or Clean with Last Settings]
                                            • 29
                                            • 30
                                            • 31
                                            • 32
                                            • 33
                                            • 48
                                            • 49
                                            • 31 / 49
