    [Plugin] CleanUp
    974 Posts 217 Posters 967.0k Views 217 Watching
    • dereiD Offline
      derei
      @thomthom said:
      What version compared to which? 3.1.5 has no change in how it cleans compared to 3.1.4...
      Got sample model? And screenshot of settings?
      Uhh, I just downloaded today last version and replaced the one I had (can't say what version I had) and I noticed that it didn't worked as I expected. Now I'm home. I'll check tomorrow and eventually I'll send you a model.
      DESIGNER AND ARTIST DEREI.UK
        Also be sure that all setting where identical between your test. Could be some some checkbox being unticked.
        • Z Offline
          Zacchia
          Tomtom
          Thanks for 3.1.5. When I "clean" nothing happens, no window pup up, when I "clean with last settings" it works like 3.1.4. Windows 7 64 bit. The window should pup up, correct? I try tomorrow at the office...
            @zacchia said:
            Tomtom
            Can you open the Ruby Console before you try "Clean..." and post back any errors?
            • Z Offline
              Zacchia
              Same thing in office. See screenshot.
                My bad. I made a minor change that required an update in TT_Lib2.
                Version 3.1.6
                Updated TT_Lib requirement to 2.5.5
                  blajnov
                  Version 3.1.6
                  Updated to version 2.5.5 TT_Lib and plug tt_cleanup.rb (Version 3.1.6), but I fall empty menu
                    Any error messages this time?
                    Btw, you're using Windows7 or Vista, right? If you go to the plugins folder in Windows Explorer, is there a Compatibility Files button visible?
                      Just noticed something odd in your screenshot:
                      "CleanUpi" - the title is suppose to be "CleanUp³" ... I wonder if your copy has been corrupted...
                        blajnov
                        Windows7 x64, previous versions worked flawlessly Cleanup
                          Any error messages in the Ruby Console?
                          Do you see a Compatibility Files button in Windows Explorer when you go to the Plugins folder?
                          • Z Offline
                            Zacchia
                            Hi Tom
                            No error message but just an empty window
                              hm... I cannot reproduce this at all.
                              btw - when you lot check the Ruby Console, you open the Ruby Console before you try to use CleanUp ?
                              Also, do you have administrator access?
                              • N Offline
                                nomeradona
                                thnaks thomas for the update.
                                visit my blog: http://www.nomeradona.blogspot.com
                                • Z Offline
                                  Zacchia
                                  Yes. I do this way. No messages in ruby console. Same thing in Windows 7 and XP.
                                  • Z Offline
                                    Zacchia
                                    Tom
                                    Can you send me the 3.1.4 Version again? I tried to replace the 3.1.6 with the 3.1.4 but the window is now also with 3.1.4 empty so I am not sure if I really have the 3.1.4 file...
                                      Can you try:
                                      1. Type in the Ruby Console: TT::Lib::VERSION
                                      2. Type in the Ruby Console: TT::System.temp_path
                                      3. Type in the Ruby Console: TT::Plugins::CleanUp::VERSION
                                      4. Right Click on the empty webdialog when you try "Clean..." and click Properties. Take a screenshot.
                                        @zacchia said:
                                        Tom
                                        Would you help trying to find the cause of the problem first? I'd like to get to the bottom of this.
                                        • jamalitoJ Offline
                                          jamalito
                                          thank so Thomas to your great work I have Q setup cleanup to my Su it tells mt it is need to TT_lib 2.5.4 but when I setup it Edge TOOL2 not work I don't know what is a problem ? thank Sir Thomas
                                          my SU is SU8
                                          Albert Einstein:
                                          ((I am enough of an artist to draw freely upon my imagination. Imagination is more important than knowledge. Knowledge is limited. Imagination encircles the world.))
                                            my SU is SU8
                                            You're saying Edge Tools doesn't work for you when you update TT_Lib? What doesn't "work"? Error messages?
                                            Have you ensured you also have the latest Edge Tools?
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 48
                                            • 49
                                            • 21 / 49
