    [Plugin] CleanUp
    974 Posts 217 Posters 958.5k Views 217 Watching
      @plot-paris said:
      actually, with your suggestion to turn off the info windows the workflow can be quite fast, even with the settings window popping up. I just have to hit Enter, and it works 😍
      That's what I do as well. And it allows for quick review and change of the settings before committing.
      • shuraS Offline
        shura
        Great improvement. Had the chance to test it on quite a few 3DS imports - works great and through the new UI has a much better access to all the functions (before I hardly ever used them). Can't thank you enough Thomthom!
        ::jingaleeeng:: If you want your models spotlessly cleeeean, ask Mr. Thomasseeeen! ::badabumtsh::
        • bagateloB Offline
          bagatelo
          Maybe we can run other older version of this fantastic plugin as well. Is it possible? Remeber: I love You!!!
            Why?
            Because of the window popping up?
            The old version has some flaws which is fixed in V3.
              Webdialog Errors
              IE7 users should update TT_Lib2 to 2.5.1 which addresses IE7 error messages with the webdialogs.
              • bagateloB Offline
                bagatelo
                @thomthom said:
                Why?
                Because the possibility to clean unneeded edges.
                  @bagatelo said:
                  @thomthom said:
                  Why?
                  That exists in CleanUp3.
                  • bagateloB Offline
                    bagatelo
                    @thomthom said:
                    @bagatelo said:
                    @thomthom said:
                    Why?
                    YES! I know it. But the problem is keyboard shortcuts. Maybe you can make possible to assign shortcuts for every option in the menu. The possible for set shortcut for unneeded edges and Merge identical materials can be great. Thank you.
                      DIEGO-RODRIGUEZ
                      as usual. excellent work. very professional.
                      thank you very much
                        @bagatelo said:
                        @thomthom said:
                        @bagatelo said:
                        @thomthom said:
                        Why?
                        That's an interesting idea.
                          Version 3.1.0
                          • Added menu item for repeating last cleanup. (scope not remembered.)
                          • Added menus for each cleanup sub-routine.
                            dedmin
                            • CAntonisC Offline
                              CAntonis
                              This is one of the best plugs ever! Great job and much appreciated!
                              Thank you!
                              • plot-parisP Offline
                                plot-paris
                                Thomthom, thats really perfect now! you made me a happy man!
                                  rv1974
                                  http://www.youtube.com/watch?v=RyUf7r_9yNs&feature=player_embedded
                                  Is this you Thom?
                                  Never thought the chill boosts the productivity so much 🙂
                                      Seems that I introduced a bug in 3.1.0 - the scope isn't properly selected. 😞
                                      Fixing...
                                        Version 3.1.1
                                        • Fixed bug where the current scope wasn't correctly pre-selected
                                        • bagateloB Offline
                                          bagatelo
                                          Great. I loved. But Now sometimes I have code error:
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;952;in `remove_materials'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;915;in `merge_similar_materials'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;477;in `cleanup!'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;420;in `show_cleanup_ui'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/tt_cleanup.rb;419;in `call'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;160;in `initialize'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;155;in `call'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `close'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;143;in `initialize'
                                          C;/Program Files/Google/Google SketchUp 7/Plugins/TT_Lib2/inputbox.rb;131;in `call'
                                          What is happening? Thanks thomthom for your efforts.
                                            Can you reproduce that in 3.1.1? (if so can you repost the message so the line numbers match with the latest version?)
                                            Also, it seems that part of that error message is missing...
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 13
                                            • 48
                                            • 49
                                            • 11 / 49
