    [Plugin] CleanUp
    974 Posts 217 Posters 1.2m Views 217 Watching
      Thanks Thomas. If it isn't difficult to fix that's fine. I guess I can live with clicking through the error messages though.
      Cheers,
      Dave
        I hope so. I'm not sure what it is - as IE8 and OSX works fine. Hopefully it's a small tweak. (Though it's IE we're talking about so... 😕 )
        If it's an easy fix I'll do it. At least for IE7.
        I tried it under IE6 and there was all kinds of weird stuff - but I'm not touching IE6 at all. Wasted enough of my live with that browser!
        • GaieusG
          Dave, if it is all the same for you (as you do not use it for internet browsing), why don't you just updgrade to IE 8 then? I also have that and have no issues (and use mainly FF for browsing).
          Certainly TT may still wish to debug his code as there may be lots of users with IE 7...
            I won't be investing much time with IE7. I've had it up to here virtual gesture with debugging Internet Explorer. It's the piece of software which has wasted the most amount of development time for so many developers that could have gone into something productive. IE the definition of what I loathe with passion. (Though IE9 is looking mighty good!)
              I did just update (I refuse to think I'm upgrading any Windows product when I install a new version) to IE8 and those messages don't appear. If no one else has the problem you might not want to spend any more time trying to fix it. Thanks for the plugin and for the time.
                I got reports in the CleanUp thread with the same errors. I assume the user has IE7, as none of the IE8 machines I've tries show this error. Must be a difference in Javascript handling.
                I'll see if I get time to poke about today.
                • plot-parisP
                  plot-paris
                  @plot-paris said:
                  ...do you think there might be a way to introduce a menu-entry to run your script with the current settings without opening the settings window at all...
                  actually, with your suggestion to turn off the info windows the workflow can be quite fast, even with the settings window popping up. I just have to hit Enter, and it works 😍
                    That's what I do as well. And it allows for quick review and change of the settings before committing.
                    • shuraS
                      shura
                      Great improvement. Had the chance to test it on quite a few 3DS imports - works great and through the new UI has a much better access to all the functions (before I hardly ever used them). Can't thank you enough Thomthom!
                      ::jingaleeeng:: If you want your models spotlessly cleeeean, ask Mr. Thomasseeeen! ::badabumtsh::
                      • bagateloB
                        bagatelo
                        Maybe we can run other older version of this fantastic plugin as well. Is it possible? Remeber: I love You!!!
                          Why?
                          Because of the window popping up?
                          The old version has some flaws which is fixed in V3.
                            Webdialog Errors
                            IE7 users should update TT_Lib2 to 2.5.1 which addresses IE7 error messages with the webdialogs.
                            • bagateloB
                              bagatelo
                              @thomthom said:
                              Why?
                              Because the possibility to clean unneeded edges.
                                @bagatelo said:
                                @thomthom said:
                                Why?
                                That exists in CleanUp3.
                                • bagateloB
                                  bagatelo
                                  @thomthom said:
                                  @bagatelo said:
                                  @thomthom said:
                                  Why?
                                  YES! I know it. But the problem is keyboard shortcuts. Maybe you can make possible to assign shortcuts for every option in the menu. The possible for set shortcut for unneeded edges and Merge identical materials can be great. Thank you.
                                    DIEGO-RODRIGUEZ
                                    as usual. excellent work. very professional.
                                    thank you very much
                                      @bagatelo said:
                                      @thomthom said:
                                      @bagatelo said:
                                      @thomthom said:
                                      Why?
                                      That's an interesting idea.
                                        Version 3.1.0
                                        • Added menu item for repeating last cleanup. (scope not remembered.)
                                        • Added menus for each cleanup sub-routine.
                                          dedmin
                                          • CAntonisC
                                            CAntonis
                                            This is one of the best plugs ever! Great job and much appreciated!
                                            Thank you!
                                            • 11
                                            • 12
                                            • 13
                                            • 48
                                            • 49
                                            • 11 / 49
