    V-Ray processing geometry Help ?
    renderpluginsextensions
    11 Posts 3 Posters 3.6k Views 3 Watching
    • zimmerklZ
      zimmerkl
      Is it normal for V-Ray to take more than an hour to process geometry? The image is of the model I'm trying to render. The trees have a ton geometry and there are a lot of solar panels in the back ground.
      Example Image
      • soloS
        solo
        Sadly yes....
        I once had a scene that took 40 minutes to process and 5 minutes to render.
        The same scene took 3 minutes to process with Twilight, so it cannot be the model but rather the way Vray handles it.
        http://www.solos-art.com
        • thomthomT
          VfSU Golden Rule: Always apply material to the faces, and faces only. Never ever apply materials to groups/components - that makes it spend an insane time parsing the scene.
          You can use this plugin to clean up the model for you - transferring group/component material onto it's containing faces. http://forums.sketchucation.com/viewtopic.php?f=180&t=13711#p102323
          If you just want to check how many Groups/Components have materials applied to them you can use this plugin: http://forums.sketchucation.com/viewtopic.php?f=180&t=21472
          • zimmerklZ
            zimmerkl
            Thanks Solo, I'm a huge fan of your work.
            One other question, Have you ever had errors pop up like the ones in the attached image? If so do you know of a solution?
            • thomthomT
              @solo said:
              Sadly yes....
              The way the current VfSU handles Group/Component with materials is that it iterates through the containing geometry and applies the material to the faces before the geometry data is fed to the render engine - then it restores whatever changes it did. This is what takes such an insane amount of time.
              ASGVis has also said that the way the current version handles components/groups is not as efficient as it can be. This is being worked on for the next version.
              • zimmerklZ
                zimmerkl
                Thanks thomthom, I had no Idea.
                Also this is the image I mentioned earlier the error on the right side occurred just after the frame buffer opened.
                • thomthomT
                  I've not seen such an error.
                  What's the memory usage of sketchup.exe when it occurs? Are you displacing large amount of geometry?
                  • zimmerklZ
                    zimmerkl
                    Thanks for the help!
                    • thomthomT
                      Is the grass added in post?
                      • zimmerklZ
                        zimmerkl
                        Yeah grass was added in photoshop, my bump map seemed to be crashing SU.
                        • thomthomT
                          Bump?
                          You don't mean displacement? Displacing large surfaces will eat up lots of ram. Large faces should be sub-divided into smaller pieces.
