    How to model this
    20 Posts 6 Posters 1.6k Views 6 Watching
      choppir
      hi guys,
      any idea how to model this that smoothly?
      http://img194.imageshack.us/img194/1613/65940715.jpg
      This is a better idea of what i mean that i did in Cinema 4D:
      http://img84.imageshack.us/img84/2706/80199616.jpg
      help will be MUCH appreciated!
      cheers
      choppir
      • soloS Offline
        solo
        Can you show more image? I cannot understand what I'm looking at.
        http://www.solos-art.com
          choppir
          cheers solo, i have updated the pics to make it more clear... πŸ˜„
            I bet Kirill's Blend Plugin would do wonders here:
            Edit - me stupid, sorry. His other plugin; 2faces+path will do the wonders needed here:
            http://forums.sketchucation.com/viewtopic.php?f=180&t=21658
              choppir
              Thanx!
              Will check it out!
                choppir
                Hi guys,
                I have tried it, but seems like it doesn't work.
                Here's the file if you wanna give it a go.
                Cheers
                choppir
                Curve New.skp
                  As far as I can remember, you need to attach the path to the faces, not to the endpoints. I don't have the plugin installed at the moment but try to move the line a bit.
                    choppir
                    thanks, i have tried it, but seems not to work.
                    will try some more.
                    thanks!
                    choppir
                      dedmin
                        dedmin
                        2 Faces + path. Weld the curve for smoother result. Use Perpendicular face tool to put faces perpendicular to the curve.
                          choppir
                          o my sack! you almost got it!
                          The end and start point should be exactly where it is drawn though...
                          will have to check how you did this.
                          Looking good man!
                          choppir
                          • jeff hammondJ Offline
                            jeff hammond
                            fredoscale's twist and bend functions make this possible in about 30 seconds.
                            see this thread
                            http://homepage.mac.com/jeffhammond/.Public/scf/twist.jpg
                            dotdotdot
                            • soloS Offline
                              solo
                              and Radial bend
                                jeff hammond
                                pete, you're missing a 180 in there 😲 πŸ˜†
                                dotdotdot
                                  choppir
                                  awesome!!
                                  cheers guys. brilliant! Jeff, that's exactly what i'm looking for.
                                  thanx again!
                                  choppir
                                    choppir
                                    i got it!
                                    When i twist it, my base point moves to an angle:
                                    http://img18.imageshack.us/img18/8339/curvenew.jpg
                                    but i have to twist 1st, then bend:
                                    http://img202.imageshack.us/img202/1184/curvenew1.jpg
                                      jeff hammond
                                      [edit --- you're missing a bend.. look at the orientation of the ends of the slats on the original picture you posted]
                                      i twisted it 90deg first... then bent it 90deg and bent it again 90deg..
                                      http://homepage.mac.com/jeffhammond/.Public/scf/twist_sbs.jpg
                                      after this, you can use the scale tool to stretch/squish it and fit it into place.. you can also set fredoscale to do the smoothing for you as you go so you don't have all those lines showing up.
                                      dotdotdot
                                      • jwlyon1J Offline
                                        jwlyon1
                                        Did you subdivide that rectangular box before doing the fredo-scale operations?
                                        Macbook Pro/ iMac
                                        OSX 10.7.2 Sketchup 8
                                        rogue-z is here!
                                          jeff hammond
                                          nah, fredoscale divides it up for you.. you can select the amount of sections but for the most part, i keep it on auto.
                                          dotdotdot
                                          • jwlyon1J Offline
                                            jwlyon1
                                            Well Dang! I guess I really need to learn how to use FredoScale. Thanks!
                                            Macbook Pro/ iMac
                                            rogue-z is here!
