    How to model this
    20 Posts 6 Posters 2.0k Views 6 Watching
    • C
      choppir
      thanks, i have tried it, but seems not to work.
      will try some more.
      thanks!
      choppir
        dedmin
          dedmin
          2 Faces + path. Weld the curve for smoother result. Use Perpendicular face tool to put faces perpendicular to the curve.
          • C
            choppir
            o my sack! you almost got it!
            The end and start point should be exactly where it is drawn though...
            will have to check how you did this.
            Looking good man!
            choppir
            • jeff hammondJ
              fredoscale's twist and bend functions make this possible in about 30 seconds.
              see this thread
              http://homepage.mac.com/jeffhammond/.Public/scf/twist.jpg
              • soloS
                and Radial bend
                • jeff hammondJ
                  pete, you're missing a 180 in there 😲 πŸ˜†
                  • C
                    choppir
                    awesome!!
                    cheers guys. brilliant! Jeff, that's exactly what i'm looking for.
                    thanx again!
                    choppir
                    • C
                      choppir
                      i got it!
                      When i twist it, my base point moves to an angle:
                      http://img18.imageshack.us/img18/8339/curvenew.jpg
                      but i have to twist 1st, then bend:
                      http://img202.imageshack.us/img202/1184/curvenew1.jpg
                      • jeff hammondJ
                        [edit --- you're missing a bend.. look at the orientation of the ends of the slats on the original picture you posted]
                        i twisted it 90deg first... then bent it 90deg and bent it again 90deg..
                        http://homepage.mac.com/jeffhammond/.Public/scf/twist_sbs.jpg
                        after this, you can use the scale tool to stretch/squish it and fit it into place.. you can also set fredoscale to do the smoothing for you as you go so you don't have all those lines showing up.
                        • jwlyon1J
                          jwlyon1
                          Did you subdivide that rectangular box before doing the fredo-scale operations?
                          Macbook Pro/ iMac
                          OSX 10.7.2 Sketchup 8
                          rogue-z is here!
                          • jeff hammondJ
                            nah, fredoscale divides it up for you.. you can select the amount of sections but for the most part, i keep it on auto.
                            • jwlyon1J
                              jwlyon1
                              Well Dang! I guess I really need to learn how to use FredoScale. Thanks!
                              Macbook Pro/ iMac
                              rogue-z is here!
