    How to model this
    20 Posts 6 Posters 1.9k Views 6 Watching
      choppir
      Thanx!
      Will check it out!
        choppir
        Hi guys,
        I have tried it, but seems like it doesn't work.
        Here's the file if you wanna give it a go.
        Cheers
        choppir
        Curve New.skp
          As far as I can remember, you need to attach the path to the faces, not to the endpoints. I don't have the plugin installed at the moment but try to move the line a bit.
            choppir
            thanks, i have tried it, but seems not to work.
            will try some more.
            thanks!
            choppir
              dedmin
                dedmin
                2 Faces + path. Weld the curve for smoother result. Use Perpendicular face tool to put faces perpendicular to the curve.
                  choppir
                  o my sack! you almost got it!
                  The end and start point should be exactly where it is drawn though...
                  will have to check how you did this.
                  Looking good man!
                  choppir
                  • jeff hammondJ Offline
                    fredoscale's twist and bend functions make this possible in about 30 seconds.
                    see this thread
                    http://homepage.mac.com/jeffhammond/.Public/scf/twist.jpg
                    • soloS Offline
                      and Radial bend
                        pete, you're missing a 180 in there 😲 πŸ˜†
                          choppir
                          awesome!!
                          cheers guys. brilliant! Jeff, that's exactly what i'm looking for.
                          thanx again!
                          choppir
                            choppir
                            i got it!
                            When i twist it, my base point moves to an angle:
                            http://img18.imageshack.us/img18/8339/curvenew.jpg
                            but i have to twist 1st, then bend:
                            http://img202.imageshack.us/img202/1184/curvenew1.jpg
                              [edit --- you're missing a bend.. look at the orientation of the ends of the slats on the original picture you posted]
                              i twisted it 90deg first... then bent it 90deg and bent it again 90deg..
                              http://homepage.mac.com/jeffhammond/.Public/scf/twist_sbs.jpg
                              after this, you can use the scale tool to stretch/squish it and fit it into place.. you can also set fredoscale to do the smoothing for you as you go so you don't have all those lines showing up.
                              • jwlyon1J Offline
                                jwlyon1
                                Did you subdivide that rectangular box before doing the fredo-scale operations?
                                Macbook Pro/ iMac
                                OSX 10.7.2 Sketchup 8
                                rogue-z is here!
                                  nah, fredoscale divides it up for you.. you can select the amount of sections but for the most part, i keep it on auto.
                                  • jwlyon1J Offline
                                    jwlyon1
                                    Well Dang! I guess I really need to learn how to use FredoScale. Thanks!
                                    Macbook Pro/ iMac
                                    rogue-z is here!
