๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
How to model this
20 Posts 6 Posters 921 Views
    choppir
    hi guys,
    any idea how to model this that smoothly?
    http://img194.imageshack.us/img194/1613/65940715.jpg
    This is a better idea of what i mean that i did in Cinema 4D:
    http://img84.imageshack.us/img84/2706/80199616.jpg
    help will be MUCH appreciated!
    cheers
    choppir
      Can you show more image? I cannot understand what I'm looking at.
        choppir
        cheers solo, i have updated the pics to make it more clear... ๐Ÿ˜„
          I bet Kirill's Blend Plugin would do wonders here:
          Edit - me stupid, sorry. His other plugin; 2faces+path will do the wonders needed here:
          http://forums.sketchucation.com/viewtopic.php?f=180&t=21658
            choppir
            Thanx!
            Will check it out!
              choppir
              Hi guys,
              I have tried it, but seems like it doesn't work.
              Here's the file if you wanna give it a go.
              Cheers
              choppir
              Curve New.skp
                As far as I can remember, you need to attach the path to the faces, not to the endpoints. I don't have the plugin installed at the moment but try to move the line a bit.
                  choppir
                  thanks, i have tried it, but seems not to work.
                  will try some more.
                  thanks!
                  choppir
                    dedmin
                      dedmin
                      2 Faces + path. Weld the curve for smoother result. Use Perpendicular face tool to put faces perpendicular to the curve.
                        choppir
                        o my sack! you almost got it!
                        The end and start point should be exactly where it is drawn though...
                        will have to check how you did this.
                        Looking good man!
                        choppir
                          fredoscale's twist and bend functions make this possible in about 30 seconds.
                          see this thread
                          http://homepage.mac.com/jeffhammond/.Public/scf/twist.jpg
                            and Radial bend
                              pete, you're missing a 180 in there ๐Ÿ˜ฒ ๐Ÿ˜†
                                choppir
                                awesome!!
                                cheers guys. brilliant! Jeff, that's exactly what i'm looking for.
                                thanx again!
                                choppir
                                  choppir
                                  i got it!
                                  When i twist it, my base point moves to an angle:
                                  http://img18.imageshack.us/img18/8339/curvenew.jpg
                                  but i have to twist 1st, then bend:
                                  http://img202.imageshack.us/img202/1184/curvenew1.jpg
                                    [edit --- you're missing a bend.. look at the orientation of the ends of the slats on the original picture you posted]
                                    i twisted it 90deg first... then bent it 90deg and bent it again 90deg..
                                    http://homepage.mac.com/jeffhammond/.Public/scf/twist_sbs.jpg
                                    after this, you can use the scale tool to stretch/squish it and fit it into place.. you can also set fredoscale to do the smoothing for you as you go so you don't have all those lines showing up.
                                      jwlyon1
                                      Did you subdivide that rectangular box before doing the fredo-scale operations?
                                      Macbook Pro/ iMac
                                      OSX 10.7.2 Sketchup 8
                                      rogue-z is here!
                                        nah, fredoscale divides it up for you.. you can select the amount of sections but for the most part, i keep it on auto.
                                          jwlyon1
                                          Well Dang! I guess I really need to learn how to use FredoScale. Thanks!
                                          Macbook Pro/ iMac
                                          rogue-z is here!
