    SU 7.1 Findings from users
    14 Posts 10 Posters 1.6k Views 10 Watching
    • brodieB Offline
      brodie
      Thought I'd go ahead and start this thread for those trying out 7.1 one and for those waiting to see how 7.1 is working.
      So far it does seem to be quicker however I've noticed some weird glitches when rotating some 2D objects. It looks as though it rotates the face or the edges but not both, however it seems to be some sort of visual glitch because as I continue working it sort of fixes itself. I'll try to post a screenshot next time it happens. Perhaps 7.1 doesn't play with nVidias drivers quite like 7.0?
      -Brodie
        Are your drivers recent?
        • K Offline
          Kent L
          Wow! Huge speed increase for me. I haven't found a model yet that will make 7.1 choke. Looks like a lot of the speed increase is by temporarily disabling shadows and other texturing during rotation and move, but they come back in less than a second after you stop moving the viewport.
          These are the kinds of performance increases we've been thirsting for.
          • F Offline
            fountainhead
            Tried download this morning. Model I was working on in 7.0 resulted in bugsplat everytime I tried to open in 7.1. Reloaded 7.0...no problem. I tried various other models with 7.1, they all seemed to open fine, but for some reason there is a glitch in the one file that 7.1 doesn't like...bummer, as it's a large file and I was anxious to see the new speed improvement others are experiencing.
              Hi Fountainhead,
              Could you report this in the SU Bug Reports subforum? Maybe some Google Folks will even wish to have a look at your model, too.
              I guess, after a new release, these things are the most important feedback for them (apart from seeing many smiley faces of course πŸ˜‰ )
              • F Offline
                fountainhead
                I copied Google a couple of times. Here's what I eventually discovered. Any model that had textures loaded when saved would bugsplat upon opening. If any other rendering style was saved, the models would open no problem. If I was in a model and then switched to textured rendering style...immediate bugsplat. So, I did some background work...updated my display driver to start. Then I went into my startup template .skp file and saved it as the new 7.1 version. I have components, materials, and styles folders referenced to same titled folders on the server and do not have these folders on my PC, so with the new update, all of these folders were re-added to my PC....I deleted those. (don't think this was the issue however). I then loaded my template .skp file and loaded all texture folders from the server, and saved. Closed and then restarted SketchUp...all worked great and have been enjoying new found speed in all files since.
                No idea what fixed the issue, but somewhere in what I described above the problem disappeared.
                • troyhomeT Offline
                  troyhome
                  I've been crashing since the upgrade. Too early to know what's been causing it, but i had three crashes with one fourty-five minute class- talk about embarrassing after exhorting all my students to upgrade!!
                  I'm on a MB Pro and no updated drivers have been posted, so i don't think it's a driver issue.
                  IOviz.com
                  SU Pro 2024 PC
                  • brodieB Offline
                    brodie
                    I updated to the newest driver for my nVidia Quadro and the little glitches I was seeing before (see original post) haven't happened again so far.
                    -Brodie
                      Aidus
                      No dxf and dwg support on free version. That's BIG dissapointment 😞
                      CPU: Intel Core i7 Extreme Edition 965
                      RAM: OCZ Gold DDR3 1600MHz 12Gb
                      Video: Asus Radeon HD4870 X2 2Gb
                      Mobo: Asus P6T Deluxe 1366 Intel X58
                        tim
                        I'm seeing some annoying behaviour when zooming/orbiting. Sometimes the textures and dimension layer(s) are not displayed whilst moving the model and sometimes they are. If they are not displayed, there is a really annoying wait after stopping moving before they re-appear. Clearly, since the system is quite capable of displaying the full picture there is no performance reason to delay the re-display and there must be some timer/flag/whatever that is set to 'annoy user maximally'.
                        It's the inconsistency that will drive people nuts.
                          MtnArch
                          Go here: http://sketchup.google.com/support/bin/answer.py?answer=161784 and you can download the DWG/DXF importer.
                          Highest Regards,
                          Alan T. Hendry, RA
                          Architect
                            TriciaS
                            @troyhome said:
                            I've been crashing since the upgrade. Too early to know what's been causing it, but i had three crashes with one fourty-five minute class.
                            Hi Troy,
                            Is it possible that you are running SketchUp without hardware acceleration? To check, go to Preferences > Open GL and see if "Use Hardware Acceleration" is checked or not. If it is unchecked, turn it on, exit SU and relaunch.
                            There is a known crash that can occur when running SketchUp in software on the Mac and doing things like orbiting, especially with large models. We are working on a fix but it has us stumped so far.
                            If that is not the issue, do you have any more information on what you were doing or whether it is specific to certain models?
                            Thanks in advance,
                            Tricia
                              Aidus
                              MtnArch thanks!
                              • troyhomeT Offline
                                troyhome
                                i'm all better now!
                                IOviz.com
                                SU Pro 2024 PC
