    Saving all scenes as JPEG?
    10 Posts 8 Posters 16.7k Views 8 Watching
    • P
      Pg09
      Is there a plug in for that? I know there is a work around with animations to produce BMPs but i would prefer JPEGs...
      Thank You!
      • TIGT
        http://www.smustard.com/scripts/ SceneExporter
        free or Pro version is $10...
        • P
          Pg09
          Very nice, thank you!
          I wonder why i suck at google searching.... πŸ˜‰
          • takesh hT
            takesh h
            Try Didier's ADO (Automatic 2D output) especially if you are on Windows machines.
            @ http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_ren_page.htm
            "Automatic 2D output from pages. Features: pages settings, images settings, creates 6 standard ortho views, creates 4 standard axonometric views, exports either standard pages, or user pages, or all pages to various bitmap and vector format files. Supported output formats: jpg,tif,bmp, tga, png, dwg,dxf,eps,pdf."
            • P
              Pg09
              Thank you Takesh, i will check out this one too!
              • GaieusG
                With animation, setting your transition (say) to 1 second and setting the output to 1 frame per second, you should be able to export to any image type not only bmp.
                • Jean LemireJ
                  Jean Lemire
                  Hi folks.
                  It is built into SU since there was a possibility to export animations.
                  In animation settings, disable scene transition and set the scene delay to 0.
                  In Menu File --> Export --> Animation choose JPG in the file type pulldown list.
                  Of course, you can set the image size and other parameters in the Options
                  When you will click on Export, one JPG will be created for each scene.
                  Just ideas
                  • J
                    Jim
                    And just more ideas - it is possible to "hack" a plugin such as proper animation to export an image for each of the movements it makes in between scenes.
                    • D
                      djh
                      Brilliant, Jean Lemire.
                      Can one export them as PDFs?
                        No but you could do that with LayOut.
