    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 438.3k Views 87 Watching
      d12dozr
      Thanks TIG, the plugin works great for importing geometry, but the UV mapped texture is coming in all black. Am I doing something wrong? I have attached a ZIP with the .obj, .mtl and 3 textures (for different times of day).
      Thanks!
      Includes .obj, .mtl, and 3 .jpgs
      http://goo.gl/f7ooYh
        Thanks!
        The files/folders in your set aren't right.
        The mtl file is looking for an image in the same folder as itself NOT the 'tex' folder. Copy the images into that base folder and it works - ensure 'textures' are switched on too...
        There's only one image called in the mtl file - you included three ?
        Open the obj and mtl files in a text editor to see what I mean...
          d12dozr
          Works perfect now!! Thanks, TIG...I am a complete newbie with .obj's and .mtl's so please forgive my ignorance 😳 I'm guessing that I'll have to manually change the .mtl to use the other 2 textures...Once again, thanks for the great plugin
            Good. If you manually change the mtl file make sure that image's file name matches exactly...
            • rami_lpmR Offline
              rami_lpm
              haha! Xfrog trees in SU models, that'll be the day.
                If you look over at ASGvis' forum you'll see a number of models rendered with Xfrog trees...
                • N Offline
                  notareal
                    tomot
                    Thank you Tig for this wonderful OBJ importer. It means I can now delete all my DXF files which I needed first so I could import into SU.
                    I'm baffled why this Import feature has not been made part of SU at this late stage of SU development. If it were not for a small group of talented Ruby Scripters, my Plugins folder would not be descending past the bottom of my monitor display. Perhaps Google could, when they find some time, add a scroll bar to the Plugins Folder, or better yet the ability to add more Plugin folders to the menu bar.
                    my plugins
                    tomot
                      sepo
                      I tried to import .obj form Modo. It keeps telling me to change import units without creating any geometry. I tried with several ones but without success.
                        It guesses the units if there are none set in the obj file.
                        The dialog let's you select the units.
                        Have you tried all of the unit options ?
                        Sometimes large/small units in the obj file affect SUp's ability to make the meshes...
                        Post a problem obj file [PM me if desired] - not too large !
                          sepo
                          It is 40mb scene. I tried several units but without real success.
                            What does it zip down to ? OBJ files are very compressible...
                            I'd try the range of metric from mm to cm and m.
                            Some very complex meshes won't import but most do...
                            • mitcorbM Offline
                              mitcorb
                              Am I reading that this Plugin works with any version of Sketchup, free or Pro?
                                Should be no difference with either version...
                                  sepo
                                  Tig , I tried it with every available units ...still nothing.
                                    sepo
                                    When zipped it is 4.3MB, still big for sending you via pm.
                                      Split it into 2 pieces and I'll join it together...
                                        sepo
                                        How about you send me your email ands I email it to you.
                                          I have the file and am looking at it now - It does have almost 1.1 million edges !!!
                                          No texture-images just materials in the mtl...
                                            sepo
                                            Yes I know....I managed to import bigger file than that, It has just over 2mil edges.
                                            • 13
                                            • 14
                                            • 3 / 14
