    [Plugin] Import OBJ with Materials v2.1 20131118
    279 Posts 87 Posters 434.3k Views 87 Watching
      Kgon
      Hey Chris , It's quite simple. There is a limited number of faces that the .3ds allows per model. The 3ds file format only supports 64 000 faces and the Highly detailed vegetation may contain more than 540 000 and a .obj supports that quantity of faceS. That's why can't converte my trees into .3ds. Well, i could import a Xfrog tree..but ....DAM !! THERE IS NOT TEXTURES...it's not supposed that this .obj Importer would keep the texture cordenates or the UV mapping?? iT WOULD BE IMPOSIBLE TO MAP 540 000 faces PROPERLY with a texture wich is a .tiff Leaf
      • TIGT Online
        Here's v1.3 http://forums.sketchucation.com/viewtopic.php?p=172790#p172790
        I've trapped errors stopping most files importing - it works fine for all modestly sized OBJs, though some very complex ones still just won't take the textures - however, since these are added to the model they could be manually applied to the group/faces afterwards...
          Khai
          oh thats nice ๐Ÿ˜„
          thank you... everything I've tried is coming in fine now ๐Ÿ˜„
            Kgon
            Thank you very much TIG , i got a xfrogg with 675000 lines-faces(don't remember)into Su but still there is textures missing ( i know, i read YOU MENTION THIS BEFORE " with complex model wont keep the textures coordinates but you can re-apply them by hand afterward..)How this can be done if every sigle face is different than the other 674999 ?(...I'M TALKING ABOUT TO MAP A TREE) i mean it would be easy if the faces were components so this could make to re-map a tree a easier work. However I REALLY REALLY APPRECIATE ALL THE EFFORT AND TIME YOU ARE PUTTING ON THIS PLUGIN TO MAKE IT WORK.
            THANK YOU SO MUCH
              raduteo
              Howdy, guess this deserves a bump, hopefully we will be able to import high poly count models into SU with textures.
                d12dozr
                Thanks TIG, the plugin works great for importing geometry, but the UV mapped texture is coming in all black. Am I doing something wrong? I have attached a ZIP with the .obj, .mtl and 3 textures (for different times of day).
                Includes .obj, .mtl, and 3 .jpgs
                http://goo.gl/f7ooYh
                • TIGT Online
                  The files/folders in your set aren't right.
                  The mtl file is looking for an image in the same folder as itself NOT the 'tex' folder. Copy the images into that base folder and it works - ensure 'textures' are switched on too...
                  There's only one image called in the mtl file - you included three ?
                  Open the obj and mtl files in a text editor to see what I mean...
                    d12dozr
                    Works perfect now!! Thanks, TIG...I am a complete newbie with .obj's and .mtl's so please forgive my ignorance ๐Ÿ˜ณ I'm guessing that I'll have to manually change the .mtl to use the other 2 textures...Once again, thanks for the great plugin
                    • TIGT Online
                      Good. If you manually change the mtl file make sure that image's file name matches exactly...
                      • rami_lpmR Offline
                        rami_lpm
                        haha! Xfrog trees in SU models, that'll be the day.
                          If you look over at ASGvis' forum you'll see a number of models rendered with Xfrog trees...
                          • N Offline
                            notareal
                            ๐Ÿ‘
                              tomot
                              Thank you Tig for this wonderful OBJ importer. It means I can now delete all my DXF files which I needed first so I could import into SU.
                              I'm baffled why this Import feature has not been made part of SU at this late stage of SU development. If it were not for a small group of talented Ruby Scripters, my Plugins folder would not be descending past the bottom of my monitor display. Perhaps Google could, when they find some time, add a scroll bar to the Plugins Folder, or better yet the ability to add more Plugin folders to the menu bar.
                              my plugins
                              tomot
                                sepo
                                I tried to import .obj form Modo. It keeps telling me to change import units without creating any geometry. I tried with several ones but without success.
                                • TIGT Online
                                  It guesses the units if there are none set in the obj file.
                                  The dialog let's you select the units.
                                  Have you tried all of the unit options ?
                                  Sometimes large/small units in the obj file affect SUp's ability to make the meshes...
                                  Post a problem obj file [PM me if desired] - not too large !
                                  ๐Ÿ‘Š
                                    sepo
                                    It is 40mb scene. I tried several units but without real success.
                                    • TIGT Online
                                      What does it zip down to ? OBJ files are very compressible...
                                      I'd try the range of metric from mm to cm and m.
                                      Some very complex meshes won't import but most do...
                                      • mitcorbM Offline
                                        mitcorb
                                        Am I reading that this Plugin works with any version of Sketchup, free or Pro?
                                        • TIGT Online
                                          Should be no difference with either version...
                                            sepo
                                            Tig , I tried it with every available units ...still nothing.
                                            • 13
                                            • 14
                                            • 3 / 14
