    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 477 Posters 4.0m Views 477 Watching
    • TIGT Online
      @rdea said:
      i laready download this plugins and the libfredo buy plugins doesnt show on the extentions toolbar ? i'm using sketchup 2015. can someone help me ?
      You will have already downloaded twp RBZ archives [probably now in your Downloads folder??].
      These need to be properly installed, one after the other [Lib first is best, but not essential].
      In v2015 the installation is done using [PC=Window >] Preferences > Extensions > Install button [in v2017 this is now found under Window > Extension Manager [dialog button]
      Click that button, find the RBZ and install it...
      After both RBZ files are installed you will need to restart SketchUp to ensure that the Lib methods are fully set up and the tool is available.
      Under the Extensions dialog ensure the LibFredo is enabled, also ensure that the RoundCorner extension is enabled.
      That extension should now have a Tools submenu menu entry and a matching Toolbar available...
      As @Pilou explained above...
        Banda
        Thank you.It's all I need.
        • V Offline
          valerostudio
          First, this plugin is one of the best. Thanks for all of your hard work. Second, any chance that we can expect a parametric option in the future? I would love to be able to turn off the corners, work, than turn back on, similar to how SubD works. Thanks again!!!
            Ricardo Marquez
            Es muy util, gracias
              Denisferragut
              Hi im new in this, and i dont know where to click and download de plug in...somo help please!
              • jujuJ Offline
                juju
                scroll to the top of the page, click on "Pluginstore", search for it there, select download
                  lilywater
                  hope it would be helpful,thanks!
                  • fredo6F Offline
                    fredo6
                    NEW RELEASE: RoundCorner v3.2a - 03 Jun 17
                    RoundCorner 3.2a is a maintenance release. It is now certified for SU2017 and also comply with a new publishing model where the Plugin information is on the Extension Store.
                    Home Page of RoundCorner for information and Download.
                    Main post of this thread.
                      tyuiop
                      Dur a installer mais très utile, prise en main très rapide, utile pour la conception d'objets pour imprimante 3d.
                      Merci! 😉
                      • fredo6F Offline
                        fredo6
                        @tyuiop said:
                        Dur a installer
                        Ou sont les 'points durs' de l'installation ?
                        Fredo
                        • H Offline
                          huu5189
                          Help me, I can't make round corner from this model
                          round corner.skp
                            What part are you trying to round over?
                              Yes. It'll skin over the opening. Just select that face and hit the Delete key and you should be good to go.
                              • I Offline
                                interconnect
                                That worked. Would never of thought to do that. Thanks!
                                • I Offline
                                  interconnect
                                  How do I round or bevel the inside edge of a circle? Whenever I do it my model gets filled somehow. I'm sure I must be missing something.
                                  • fredo6F Offline
                                    fredo6
                                    NEW RELEASE: RoundCorner v3.2b - 24 Jun 17
                                    RoundCorner 3.2b is a maintenance release. It fixes a bug when selecting edges interactively in certain situations (usually with corners of 4 edges and more).
                                      secretling0617
                                      非常感謝分享~~
                                        tramspotters
                                        Great plugin, but unfortunately on a Macbook with Retina display the toolbar is really tiny. Is it possible to consider this in the next update?
                                          barakuda
                                          RoundCorner is great tool. I used it in SU8 to perform small modifications of terrain (squares 5mx5m).
                                          I have tested versions 2.3 and 3.2b (current). To compare.
                                          With v2.3 I have found problem when I try to select edges and junctions idividualy. The arro color often changes from blue or from orange to red. This is not what I want. Because the SU8 reacts slowly, often happened to me often that the selection which I did was removed because the red arrow was there. I mean, it was not visible, but the SU thinks like it is there because the SU runs slowly when it must work with a lot of entities. Hence for this selection I found the red arrow completely useless. I please, you either remove it from your program or give option to disable the function of complete selection of edges using red arrow. For me this is discomfort and frustrationg when I can not disable it.
                                          In v3.2b. The selection of individual edges is more easy than in v2.3. Less work. But the SU8 have crashed after a minute of work. So I have to uninstall the 3.2b and I hope in the next version you will fix the problem.
                                          Thank you for your tool
                                            barakuda
                                            Once again testing 3.2b
                                            and this error occured:
                                            Ruby Error - Round Corner - 03-Jul-17 13_10_04.txt
                                            Date: 03-Jul-17 13:10:04
                                            An error occurred in Round Corner
                                            Error
                                            Cannot convert argument to Sketchup::Point3d
                                            (eval): 1878 -- add_edges
                                            (eval): 1878 -- robot_protected
                                            (eval): 1874 -- each
                                            (eval): 1874 -- robot_protected
                                            (eval): 1854 -- robot
                                            (eval): 1848 -- robot_top_execute
                                            (eval): 332 -- call
                                            (eval): 332 -- step_geometry
                                            (eval): 293 -- yield?
                                            (eval): 605 -- call
                                            Please contact me if you want to solve this bug.
                                            • 57
                                            • 58
                                            • 59
                                            • 60
                                            • 61
                                            • 74
                                            • 75
                                            • 59 / 75
