    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 477 Posters 4.3m Views 477 Watching
    • OxerO
      Oxer
      If you have installed correctly the plugin in User/Library/Applications Support/Sketchup 2013/Sketchup/ Plugins, go to View Menu/Toolbars/..... and mark the Round Corner to see its toolbar.
      http://www.oxervision.blogspot.com/
      • TIGT
        Also ensure that it is enabled [checked] under Preferences > Extensions...
        Otherwise its Toolbar isn't available...
        • M
          michelleyeo
          Dear TIG and Oxer,
          Many thanks for your reply.
          I've installed correctly and enabled the extensions however no sign for Roundcorner.
          Please helpppp
          • BoxB
            Are you saying that if you put your mouse on the words "Tool Palettes" you don't get round corner in the list that pops up? or haven't you found that list of toolbars yet.
            • M
              michelleyeo
              Yes, I don't get the round corner in the list
              • jeff hammondJ
                jeff hammond
                @michelleyeo said:
                Dear TIG and Oxer,
                Please helpppp
                according to your second picture, you haven't installed it correctly.. you're missing libFredo files.
                you can get that here:
                http://sketchucation.com/forums/viewtopic.php?t=17947
                (download the .rbz version underneath the word DOWNLOAD in the first post)
                to install it, go Sketchup (menu)-> Preferences-> Extensions..
                click the 'Install Extensions' button at the bottom then navigate to the libFredo .rbz file... it will be placed in the proper location for you..
                dotdotdot
                • W
                  wisar
                  Great tool but I am wondering if I can undo the rounded corners if I want to revisit a design and make some changes like pushing and pulling a face?
                  Cheers,
                  W
                  • mitcorbM
                    mitcorb
                    Hi:
                    You can undo the rounded corners while in the same session, but you cannot undo the round corners tomorrow.
                    If you were using Blender you could simply switch it off, because rounded corners would be a modifier "channel"(?).
                    In Sketchup, do the rounding on a separate copy, group or unique component of the original geometry.
                    You could then save these copies out of your working file if you wish.
                    • L
                      Lyubov
                      Please, help me to delete plugin from SketchUp Pro 2013, after Setting plugin Fredo6_Round Corner i decieded to delete him from foulder plugins, but now after openning SketchUp I have every time notice about that I have to install this plugin...(YOU MUST INSTALL LIBFREDO6 VERSION 5.2 OR HIGHER TO RUN FREDO ROUND CORNER)... Thank you so much for helping!! 😒
                      • mitcorbM
                        mitcorb
                        Hi, Lyubov:
                        Your question generates many questions.
                        Please visit this thread and see if an answer is there:
                        http://sketchucation.com/plugin/696-SketchUcationTools
                        Fredo6's RoundCorner is a very reliable plugin and requires a helper file called Libfredo. In fact, most if not all of his tools utilize the helper file.
                        See if the above helps and post back if you need further assistance.
                        Someone is sure to respond.
                        • frankflafyF
                          frankflafy
                          is it compatible with su2014? im trying and still get error.
                            Round Corner is indeed compatible with SU2014. What error do you get? Just saying you get an error is useless.
                            Make sure you've installed the current version of Round Corner AND Libfredo6.
                            • frankflafyF
                              frankflafy
                              sorry i just copy paste old plugins to a new plugins folder. and i got screwed.
                              but it fixed. thanx community.
                                Frank, it has been posted all over Sketchucation that copying and pasting plugins from an older installation is not advised.
                                • K
                                  keramare
                                  THANX again
                                  • A
                                    Antonius43
                                    Just do not understand, do I need to pay for this plugin to work? After following the instructions I cannot find the toolbar? What a waste!!!
                                    • massimoM
                                      massimo Moderator
                                      No.
                                      What a waste!!!
                                      Waste? this is a great and must have plugin and many people use it successfully.
                                      Correct.
                                        Maybe you wil be more lucky with this!
                                        Now there is a sort of integration of it inside Join PusPushPull Interactive!
                                        • TIGT
                                          It is free to download, install and use [but of course you are free to donate to authors]...
                                          If you have installed the Plugin properly [and how did you do that?]... then you might need to restart SketchUp and activate the it under Preferences > Extensions... and then activate its Toolbar...
                                          Also having read the Plugin's installation instructions... you will be aware that you also need to have 'LibFredo' downloaded and installed to make this work [that's free too 😉 ]
                                          • S
                                            synthkim1
                                            Thank u so much,,,it's amazing
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 46
                                            • 74
                                            • 75
                                            • 44 / 75
