    [Plugin][$] RoundCorner - v3.4a - 31 Mar 24
    1.5k Posts 477 Posters 4.1m Views 477 Watching
      Dunno - it's very strange. Unless they where both installed at the same time - incorrectly. ...but VfS has an installer.
      Screenshot of the plugins folder?
      • E Offline
        eshghe_2p
        @dave r said:
        Reread the first post of the thread and install LibFredo6 as it tells you. πŸ˜’
        thanks a lot! πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜› πŸ˜›
          Does that mean installing LibFredo6 fixed your problem?
          • E Offline
            eshghe_2p
            yes it does. but when i want to use this plugin recive this error :
            http://photos.uvs.ir/img/18ac3fe3df6f.jpg
            what i have to do ?
              First off it's Trimble now, so you have an older version of SketchUp 8...
              What are you trying to do when it splats ?
                I recommend you update as they try to fix causes to BugSplats in every release.
                • E Offline
                  eshghe_2p
                  my sketchup is pro
                  does it mean i have to installing google sketchup 8 im my camputer again ?
                    No! Just install the current version. It hasn't been Google SketchUp since the middle of last year. Just update to the current release. Click on Help and Check for Updates.
                    • E Offline
                      eshghe_2p
                      when i do this work give this massage :
                      Due to US Export Regulations, we are unable to process your request at this time.
                      what i have to do new ?
                        Contact SketchUp Customer Support on Monday.
                        • E Offline
                          eshghe_2p
                          ok thanks
                          but how to do it?
                            Try this.
                            • E Offline
                              eshghe_2p
                              @dave r said:
                              Try this.
                              thank you very much πŸ˜„
                              good luck
                                mikedifilippo
                                So I cant get the round corner plugin to work. I installed Fredo6 and then round corner, the 3 tool toolbar shows up but NOTHING ELSE. Here is a screen shot. Can anyone help?Screen Shot 2013-02-24 at 11.20.47 PM.png
                                Sketchup version 8.0.16845
                                and fredo and round corner are up to date according to the "check plugins for up to date"
                                • fredo6F Offline
                                  fredo6
                                  Can you open the Ruby console and tell if you see an error message when you click on a RoundCorner icon.
                                  Also check the dimension of the offset in the palette and the dimensions of your model.
                                  Finally, this type of problem may come from a conflict with other plugins.
                                  There is a list of plugins known to create some comaptibility problems at this post. This may clash with RoundCorner.
                                  Fredo
                                    mikedifilippo
                                    Thank you for the quick response. Yes, if I click the first tool this comes up in the ruby console, I have no other plugins installed.
                                    "Error: #<Errno::EACCES: Permission denied - /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/Fredo6Trace.txt>
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in initialize' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in open'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in trace6' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:314:in init_palette'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:127:in initialize' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in new'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:42:in launch' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/RoundCorner_Tool.rb:33:in action__mapping'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:132:in call' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:132:in launch_action'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:143:in launch_action' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/ROUNDCORNER_Dir_23/bootstrap_RoundCorner.rb:159:in startup'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1092:in call' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1092:in command_invoke'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Plugin.rb:1074:in build_config_commands' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Traductor.rb:1061:in call'
                                    /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Traductor.rb:1061:in add_command' /Library/Application Support/Google SketchUp 8/SketchUp/Plugins/LIBFREDO6_Dir_47/Lib6Core_47.rb:712:in call'
                                      mikedifilippo
                                      I think I got it, I went to my plugins folder and permissions were set to read only, i made it read and write and now it shows up
                                        burnedchicken
                                        Yes, I can confirm that this also fixed it for me on MacOX 10.7.5
                                        thanks for the cool plugin btw. This is life-saver....
                                          daviddeboer
                                          I just downloaded the Roundcorners Plugin, and it shows up when I open Sketchup under View<Tool Palettes<Round Corner, but once I open it up and try to use it, nothing happens. I can see the toolbar, and I can select any one of the three options, but from there...nothing.
                                          I'm not sure if I downloaded it wrong or what, but anyone have any ideas?
                                            Most likely an installation error. Make sure you put all of the required files where they belong when you installed it. also make sure you installed LibFredo6 correctly as well. In both cases the info you need is in the first posts of the threads. Also, as indicated in the first post of this thread, make sure you've enabled full read and write permissions for the Plugins folder.
                                            • 32
                                            • 33
                                            • 34
                                            • 35
                                            • 36
                                            • 74
                                            • 75
                                            • 34 / 75
