    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 219.6k Views 61 Watching
    • boofredlayB Offline
      boofredlay
      Thanks.
      • CadFatherC Offline
        CadFather
        Hi Didier, regarding your smooth problem - have a look at Matt's script here
        http://forums.sketchucation.com/viewtopic.php?f=180&t=11317&hilit=plugin
        • Didier BurD Offline
          Didier Bur
          Hi Cadfathher,
          Thanks a million. I knew that smoothing was possible, but the ruby doc is REALLY bad, it doesn't mention that an edge can be smoothed only when it shares 2 faces.
          It works now. Patch published.
          DB
            CadFather
            fantastic ๐Ÿ‘
              CadFather
              wonder if anyone has the same thing - when i use extrude lines, i cannot draw the vector easily - it stop/starts or disappears.
              only with difficulty i can align it along an axis..
              will keep an eye if there's a clash somewhere
              • Bob JamesB Offline
                Bob James
                @boilingsnow said:
                What you have is not the latest version...so you can get or the buttons loaded.
                The Projection folder I have is dated 6 July 2009 and I downloaded the "Projection Patch" but I don't see any difference. What am I missing?
                  CadFather
                  Hi Didier,
                  this is what's happening - the inferencing works well when you have faces behind the cursor.
                  it snaps strangely when in empty space
                  thought i'd cheer you up for the day... ๐Ÿ˜’ ๐Ÿ˜„
                    It's me or when using undo with for exemple the Extrude line along a vector all the lines are killed ๐Ÿ˜ฎ
                    It's some annoying when you have made 10 extrude lines successive all is to remake ๐Ÿ˜‰
                    Does not possible to have a real undo successive?
                      Didier Bur
                      Hi Pilou,
                      Someone asked me (a long time ago I confess) to have a global undo instead of a step by step undo. How to satisfy everybody ?
                      In french: on m'a demandรฉ il y a longtemps de faire un annuler global plutรดt que par รฉtape. c'est l'un ou l'autre, c'est difficile de contenter tout le monde...
                      DB
                        Didier Bur
                        Nothing. The new RBS is an update of the "extrude lines tool" to have smoothed surfaces when extruding curves, arcs, and circles.
                        Regards,
                        DB
                          Didier Bur
                          Hem hem,
                          Inference when there's no face behind cursor snaps to the Red-Green plane as I see ๐Ÿ˜ฎ
                          Must look into it...
                          DB
                            Damned! ๐Ÿ˜ฎ
                            It's very more subtle to have a partial Undo than a global Undo for this sort of function (just 10 clicks than a painful remake ๐Ÿ˜ฎ
                            It's even absurd! ๐Ÿ˜ฎ
                            As the drawing of the vector is not so evident, an error is speedy arrived! ๐Ÿ˜ณ
                            I am very disappointed ๐Ÿ’š
                              DIEGO-RODRIGUEZ
                              a question.
                              How can extrude line and get the result of this image?
                              http://forums.sketchucation.com/download/file.php?id=29592&t=1
                                TIG's extrudeEdgesByRails.rb... NOT yet on general release...
                                  dylan
                                  Look forward to it's release TIG ๐Ÿ‘
                                  http://dmdarchitecture.co.uk/
                                  • H Offline
                                    Heven7_floor
                                    Thanks for your wonderful created things โ˜€
                                    and kindly sharing for helpfully used in SU ๐Ÿ’š
                                    Cheer ๐Ÿ‘ ๐Ÿ‘
                                    • EdsonE Offline
                                      Edson
                                      hi didier,
                                      would it be possible to include something in the code of PROJECTIONS that would remember the state of the tool bar (open or closed) when sketchup is opened, much like you did for Layer Manager? ok, you suggested we do it but it works the same way.
                                      thanks.
                                      edson mahfuz, architect| porto alegre โ€ข brasil
                                      http://www.mahfuz.arq.br
                                      • K Offline
                                        K-TEE
                                        the best mission
                                          Didier Bur
                                          mission
                                          ??? ๐Ÿ˜ฒ
                                          DB
                                          • aadbuildA Offline
                                            aadbuild
                                            Well done Didier, I dont know if any one else uses this for dimensioning but it saves so much time. I use guides to dimension so that the leader does not go through the model. It takes hours to dimension this way and now it takes minutes.
                                            One question I read on the sketchucation forum that this plugin lets you assign attributes to faces . I did not see this... Must be a miss print
                                            Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
                                            https://www.plusspec.com
                                            • 6
                                            • 7
                                            • 8
                                            • 4 / 8
