    [Plugin] Projections version 2a UPDATED
    145 Posts 62 Posters 223.4k Views 61 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      It's time for an update of my projection and guides tools set, with new features and more interactive tools.
      What's new ? Everything.
      PDF doc included.
      Here's the toolbar:
      Updated 29.06.09: 4 new tools and several bug fixes
      Updated 03.07.09:
      • a new tool by TIG (thanks to him)
      • you can now select what guides to erase: SU guides, plugin guides or all guides
      • edges are soften when extruding arcs, circles and curves.
      Developpers note: anyone knows how to smooth surfaces ? entity.smooth=true doesn't seem to work as expected.
      Patch on 05.07.09 (missing icons) 😳
      Patch on 08.07.09 just the RBS, including faces smoothing when extruding curves.
      Download the latest version from the PluginStore...
      http://sketchucation.com/pluginstore?pln=projections
      Older versions...
      Unzip in your Plugins folder
      Remove previous version if any !
      Version française.
      A dezipper dans votre dossier Plugins.
      Unzip in the Projection sub-folder and verwrite your existing file with this one.
      A dezipper dans le sous-dossier "Projections" de "Plugins". Remplacer votre ancien fichier par celui-ci.
      DB
        troyhome
        Thanks so much! i'm going to try it out right now!
        IOviz.com
        SU Pro 2024 PC
        • massimoM Offline
          massimo Moderator
          Hi Didier, first of all thanks for this great update (i especially like tools n#4 and n#5). I tried it quickly and i had two problems.
          1. In SU 6 i overwrote the folder and the .rb file on the older projections ones. I opened SU, the new toolbar was there but, with the exception of the point tool, nothing worked. So i deleted the .rb file and the folder from the plugins folder, i reinstalled them and that worked. But..
          2. The tool n#2 seems not working properly. The temporary display appears, but when i click on a face, for example on a cube face, the behaviour of the tool is strange. Sometimes it draws only 3 construction lines, sometimes nothing. The same happens with a line click.
            Maybe my fault?
            Thanks.
            Massimo.
            silver_shadow
            gonna give it a shot, thanx
              dmatho
              Ahhhh-mazing! Thanks Didier!
              Cheers,
              • Diego -
                Didier Bur
                Hi Massimo,
                You found the first bug !
                The automatic guides cleaner is guilty 🎉
                Let's wait a little for other bug reports, and I'll publish a patch.
                Thanks for reporting,
                DB
                  AH cool this new version ! 👍
                  Whish there is the extrude along vector with selection at the end 😄 (yes it is!)
                  Bravo 😎
                  Ps Extrude along a vector will be absolutely terrific if "offset" (or tricky sign of vector) can be integrated when necessary!
                  Maybe with CTRL pressed?
                  Because if I use the normal offset I lost the selection for follow the extrude along a vector! 😮
                  Allez Didier un dernier petit effort et c'est gagné! ☀
                  • urgenU Offline
                    urgen
                    ....many thanks Didier! 👍
                    --pupil forever...------
                    • massimoM Offline
                      massimo Moderator
                      I've played a bit with tool n#5 with 4 divisions.
                      Maybe another bug?
                      • CadFatherC Offline
                        CadFather
                        glad to see Didier is back.. Thanks Didier!
                        • MALAISEM Offline
                          MALAISE
                          Hi, Masters are back ! 👍 👍
                          I'll try it very soon.
                          MALAISE
                            Didier Bur
                            Massimo,
                            I cannot reproduce the division problem. How do you do it ?
                            DB
                            • I Offline
                              ideas_arte
                              Many thank you very much ..!
                              If the first is very good, this is much much better ..!
                              Thanks friend ..! 😍
                              • massimoM Offline
                                massimo Moderator
                                Really strange. I've tried again. Sometimes works and sometimes not. Simply draw a rectangle then pushpull. Copy the solid along the green axe and apply to the first solid "insert guide at divisions" horizontally (it works), press esc, and then apply to the second the tool vertically (sometimes it doesn't works). The same happens (never works) if you try to do that on a single face in order to have a grid (horizontally + vertically).
                                Maybe it's only my problem?
                                  Didier Bur
                                  Unfortunately I think it is your problem, because what you describe always work on my side...
                                  DB
                                  • mitcorbM Offline
                                    mitcorb
                                    could it be camera position relative to horizon when selection is done? probably not, just wondering.
                                    • massimoM Offline
                                      massimo Moderator
                                      Unfortunately nothing to do with camera position, Mitcorb. Don't understand why but it simply doesn't work for me.
                                        Any chance to integrate an "Offset" or similar in the "Extrude line along a vector"?
                                        • massimoM Offline
                                          massimo Moderator
                                          Hi Didier and thanks for your patience. When i use for the second time "insert guides at divisions" some lines are missed (very often the middle line) but i've noticed that if i click a little bit below the edge of the solid it works fine. Maybe this makes some sense to you?
                                          • urgenU Offline
                                            urgen
                                            ... hi Dider! ....is it possible to add old function "create lines at intersection of selected faces" in a script?...It's very useful function 😕 ....I do not want come back to old script "ClineAtFaceIntersection.rb" 😒
                                            • 6
                                            • 7
                                            • 8
                                            • 1 / 8
