    Unable to fill in areas with color
    19 Posts 7 Posters 1.4k Views 7 Watching
    • N Offline
      NHMatt
      I have a model I was making up the Plan View. It is just a flat drawing with various arcs and angles. I was able to fill in a lot of the areas but on a few it stays white and isn't able to be painted. I zoomed in super close and made sure all the intersections are closed up but it still is acting like it has a gap somewhere. I went around the whole thing redrawing the lines and still nothing. Any ideas, Thanks.
        remus
        Have you got a pic of the problem? or even better the problem model itself?
        • N Offline
          NHMatt
          Its kind of an embarassing picture that I was doing for my kids. It is a copyrighted picture of the South Park cartoon characters and don't want to get into trouble for publishing online. Also, now that I am looking, How do I upload pics on this site? I am not seeing an upload button. Thanks.
            When you reply - under the textarea there's an "Upload attachment" tab.
            Could you post the model without the picture? Just plain material?
            • N Offline
              NHMatt
              I don't know why the hell I didn't see that before. Thanks. In the picture you will see that their jackets are white. I wanted to give them the reddish color that they are supposed to be.
                I'd think that eitehr, you've lost teh face tehre.
                Or, you might have multiple faces on top of each other. - in taht case you might select one face, but when you use the paintbucket you paint one of the others.
                • N Offline
                  NHMatt
                  The strange part is that it was drawn on 1 plane 2d. when you spin it all around, it is all in line and even. I have even erased all the lines and drew it again and the same thing happened. Oh well. I'll try it again later.
                    remus
                    You could try drawing lines to segment the face and so try and find the problem area.
                    • N Offline
                      NHMatt
                      I have redrawn and followed the lines, Zoomed in insanely close and followed every line and can't find the space. Here is the finished product, with exception to the problem areas.
                        Maybe this plug can help you!
                        It detect and show holes on a surface!
                        Label open face by Chris Fullmer
                        What append when you select the lines and make an extrude?
                        With Didier Bur projection2 plug
                        News for today! 😎 😎 😎
                        And why not Scale all the project? *1000
                        Maybe you work with too small unit?
                        • N Offline
                          NHMatt
                          Being a welder by trade, Computers are an uphill battle for me. I downloaded the file but how do I use it and apply it to SU?
                          • N Offline
                            NHMatt
                            As far as scale, the heads are about 6' in diameter.
                            • N Offline
                              NHMatt
                              There must have been a hiccup in it. I erased it again and redrew them now its better. Thanks guys.
                                For use a plug just copy the unzipped (uncompress if it's a zip file) result inside the Plugins folder of SU
                                You must have new icons on the board or new menu lines inside Menu Plugins
                                  When you have a closed, even coplanar set of edges, the face will still not be created i there are stray lines "sticking inside" (on the same plane). They somehow break the face creation (see attached).
                                  Now don't take this necessarily a bug - as if you know about it, it can be avoided easily (just draw those "offending lines" aftermaking the face).
                                  In fact, you can even turn this onto your advantage and stop faces getting created say when you are modelling an interior from above and the ceiling keeps filling in all the time - when an appropriate edge is (re)drawn - blocking your sight and forcing you to keep deleting it.
                                  • Alan FraserA Offline
                                    Alan Fraser
                                    I identified the problem of the lines on the inside of the arms...I get that every day when doing 2D Face Me figures...but I never thought of turning it to an advantage like that Gaie. Brilliant. πŸ˜„
                                    I usually fill such problem areas by drawing extra lines connectiong the ends to somewhere on the edge, then erasing them again when the face finally fills in.
                                    3D Figures
                                      Well, I was actually going to give credits to whom I thought I'd learnt it from and it was either you or Wodan (or somebody else?) but then due to my uncertainty I didn't do it. And now you say you didn't know this "trick"...
                                      Now you see you never know (after years of using and still learning SU) who you should be thankful to on a forum. πŸ˜„
                                        If you select all of edges and use a 'face edges' script then it will make a face - even with the rogue edge that extends into the face.
                                        If you redraw one edge that's next to the rogue edge that extends into the face you will make a face.
                                        If you redraw one edge that's NOT next to the rogue edge that extends into the face you will NOT make a face.
                                          @tig said:
                                          ...If you redraw one edge that's next to the rogue edge that extends into the face you will make a face.
                                          Yes, I remember these "rules" (now).
                                          Always good to remember. πŸ‘
