    [Plugin] Sculpt Tools (help)
    188 Posts 46 Posters 88.5k Views 46 Watching
      Daniel S
      I can´t see the icons on the toolbar but the plugin seems to work.. but very slow for me.. I will keep trying
      Thank you!!
      Daniel S
      • soloS Offline
        solo
        I unzipped it into my SU6 plugins folder, but cannot see icons nor the plugin in the drop down menu. 😕
        http://www.solos-art.com
          BTM
          This page might explain one of the problems with the zip files macs make.
          http://forums.sketchucation.com/viewtopic.php?f=180&t=19838&start=60
            leixing
            Thank you!!
            Daniel S
            I have the same problem.I think i did the right work.
            Thank you BTM.
            • Chris FullmerC Offline
              I sent him an updated .zip file a while ago. Hopefully he'll post it soon.
              But otherwise, you have to dig in a level intothe btm_sculp_tools folder. Then copy the single .rb file from there and the folder into your plugins folder. Then it will work (but as noted previously, the icons do not show up, its just a big blank toolbar (with tooltips though)). And the toolbar buttons appear twice, so its twice as big as it should be.
              You should be able to get it installed if you do that though.
              Chris
              All my Plugins I've written
                I REALLY like the smooth tool. Its a lot of fun, as are all the other ones.
                I am wondering about the dual icons in the toolbar and the lack of toolbar icons. Are you seeing that also on the Mac? Or is that only happening on the PC?
                I'm looking for the problem, but so far I have not found it. I'm not sure if I'm just missing something obvious (I don't make toolbars all that often really). Or I am kind of thinking that your pressing your luck with the global variables holding all the menu information. You might simplify it by combining all the scripts into a single file, and remove the menu globals from the loader script. Just do all the menu stuff from the single main script in the folder.
                But again, perhaps that has nothing to do with it. I really haven't found anything concrete.
                Good luck with it, its awesome!
                Chris
                • PixeroP Offline
                  Pixero
                  Very nice. 👍
                  I don't get the icons but I don't get them twice as you.
                  I'm on XP.
                    sepo
                    No change for me. It is same as before.
                      BTM
                      … Weird 😕 The icons work for me, and, although ugly, look like this.
                      I need better icons…
                      I can't seem to find any problems either.
                        BTM
                        @cadfather said:
                        BTM, the problem is that you are calling the tools with different toolbars,
                        look in the extensions menu under preferences and you will find bulge, push etc
                        go to view toolbars and you will find your sculpt (sculp) as well
                        I actually just found out about the typo a few minutes ago 😆 The current file up is now easier to download, but still has the typo. As for me though, I only have the 1 toolbar anyways. 😕
                        • CadFatherC Offline
                          CadFather
                          BTM, (Edit: 'i think') the problem is that you are calling the tools with different toolbars,
                            CadFather
                            i got the feeling it's somewhere here.. toolbar = $btm_sculpt_toolbar.add_item mgp
                            (i might just get out some tarot cards)
                            • majidM Offline
                              majid
                              First of all, thanx for such brilliant tool..it was one of my dreams... 👍 👍 👍
                              It worked for mr ,but seems to me that I'v missed icons.
                              • BurkhardB Offline
                                Burkhard
                                I've played around and get the Icons to work. The files are send to BTM.
                                [http://www.ia-plus.de(http://www.ia-plus.de)]
                                  BTM
                                  Wait, so all it needs is the small icons? 😲
                                  I thought that I didn't need small icons, as my mac will automatically turn the large ones into 16x16's, if I set it to small.
                                  I'll change the scripts as you did to have small icons too. If there are still issues, let me know.
                                    Jim
                                    You don't need to make separate small icons if you set the small icons to the same image as the large icons. But hand-made small icons usually look better than having SketchUp shrink the large ones. But I now remember having the same problem until I set the small icons to something, rather than nothing.
                                      Click Draw
                                      So.....all good to go now...shall I download it? Excited!!!!
                                      Jeff
                                      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                                      • BurkhardB Offline
                                        Burkhard
                                        I'm not sure if these changes are the only ones ( that's what I call "playing around" ) But I remember I put also the # in front of some header lines.
                                          Jim
                                          Pretty remarkable, btm. Here's 15 minute test.
                                            sepo
                                            Jim ..How did you make it work?
                                            • 6
                                            • 9
                                            • 10
                                            • 4 / 10
