    [Plugin] Sculpt Tools (help)
    207 Posts 48 Posters 121.7k Views 48 Watching
      sepo
      Donno if this is what you wanted
      if flags == 256 + MK_LBUTTON
      Error: #<SyntaxError: (eval):131: compile error
      (eval):131: syntax error
      (eval):131
      • B
        BTM
        (eval):131
        uh… not exactly. more like
        ` class Flagtest
        def onMouseMove(flags,x,y,view)
        UI.messagebox flags
        ftest = UI::Command.new("Flags Test") { Sketchup.active_model.select_tool Flagtest.new }
        UI.menu("Plugins").add_item ftest`
        … Put that into the Ruby Console, and then go to plugins, Flags Test. Move the mouse, and tell me what number pops up.
        … Now that I think about it, is there any chance you put the files in the wrong spots? The problems you're having seem to say so… the Loader should go in the plugins folder, and the rest of the pictures and scripts should go in their folder, inside the plugins folder.
        • Chris FullmerC
          It is zero on PCs
          How have you implemented the modifier keys?
          • B
            BTM
            @chris fullmer said:
            It is zero on PCs
            …Using flags. So, I guess that means I'll have to change the script again 😉 Sorry guys. Also, if anyone can test this on a mac, does it work on yours too?
            • BurkhardB
              Burkhard
              I will do tomorrow. Now it is too late.
              http://www.ia-plus.de
              • B
                BTM
                Okay, the file has been updated, it SHOULD work with windows now too. Still, if there are any problems, let me know.
                http://forums.sketchucation.com/download/file.php?id=30042
                • CadFatherC
                  CadFather
                  ..good thing i'm still up - Thank You!! 👍 ☀
                    Daniel S
                    I can´t see the icons on the toolbar but the plugin seems to work.. but very slow for me.. I will keep trying
                    Thank you!!
                    Daniel S
                    • soloS
                      I unzipped it into my SU6 plugins folder, but cannot see icons nor the plugin in the drop down menu. 😕
                      • B
                        BTM
                        This page might explain one of the problems with the zip files macs make.
                        http://forums.sketchucation.com/viewtopic.php?f=180&t=19838&start=60
                        • L
                          leixing
                          Thank you!!
                          Daniel S
                          I have the same problem.I think i did the right work.
                          Thank you BTM.
                          • Chris FullmerC
                            I sent him an updated .zip file a while ago. Hopefully he'll post it soon.
                            But otherwise, you have to dig in a level intothe btm_sculp_tools folder. Then copy the single .rb file from there and the folder into your plugins folder. Then it will work (but as noted previously, the icons do not show up, its just a big blank toolbar (with tooltips though)). And the toolbar buttons appear twice, so its twice as big as it should be.
                            You should be able to get it installed if you do that though.
                            • Chris FullmerC
                              I REALLY like the smooth tool. Its a lot of fun, as are all the other ones.
                              I am wondering about the dual icons in the toolbar and the lack of toolbar icons. Are you seeing that also on the Mac? Or is that only happening on the PC?
                              I'm looking for the problem, but so far I have not found it. I'm not sure if I'm just missing something obvious (I don't make toolbars all that often really). Or I am kind of thinking that your pressing your luck with the global variables holding all the menu information. You might simplify it by combining all the scripts into a single file, and remove the menu globals from the loader script. Just do all the menu stuff from the single main script in the folder.
                              But again, perhaps that has nothing to do with it. I really haven't found anything concrete.
                              Good luck with it, its awesome!
                              • PixeroP
                                Pixero
                                Very nice. 👍
                                I don't get the icons but I don't get them twice as you.
                                I'm on XP.
                                  sepo
                                  No change for me. It is same as before.
                                  • B
                                    BTM
                                    … Weird 😕 The icons work for me, and, although ugly, look like this.
                                    I need better icons…
                                    I can't seem to find any problems either.
                                    • B
                                      BTM
                                      @cadfather said:
                                      BTM, the problem is that you are calling the tools with different toolbars,
                                      look in the extensions menu under preferences and you will find bulge, push etc
                                      go to view toolbars and you will find your sculpt (sculp) as well
                                      I actually just found out about the typo a few minutes ago 😆 The current file up is now easier to download, but still has the typo. As for me though, I only have the 1 toolbar anyways. 😕
                                      • CadFatherC
                                        CadFather
                                        BTM, (Edit: 'i think') the problem is that you are calling the tools with different toolbars,
                                        • CadFatherC
                                          CadFather
                                          i got the feeling it's somewhere here.. toolbar = $btm_sculpt_toolbar.add_item mgp
                                          (i might just get out some tarot cards)
                                          • majidM
                                            majid
                                            First of all, thanx for such brilliant tool..it was one of my dreams... 👍 👍 👍
                                            It worked for mr ,but seems to me that I'v missed icons.
                                            • 11
                                            • 4 / 11
