    [Plugin] Sculpt Tools (help)
    207 Posts 48 Posters 121.7k Views 48 Watching
    • KrassK
      Krass @Krass
      • KrassK
        Krass
        This post is deleted!
        • KrassK
          Krass
          no ! the best solution is to use SketchUV plugin!
          SketchUp_ZBpNK5VUlK.mp4
          Didier BurD 1 Reply Last reply
          • TIGT
            If it's a single 'image' can you make its textured material 'projected', and then save it to another face of the same orientation. Can you then adjust the original surface - after which you use the eyedropper to select the projected texture from the temporary face, and reapply that onto the modified original surface ? hereby keeping the UVs ?
            • KrassK
              Krass
              That may be, but I don't see a faster, more effective, and free solution than the one I showed in the video above (the second one).
              • TIGT
                Your video arrived as I was posting - just consider it an alternative approach...
                • Didier BurD
                  Didier Bur @Krass
                  @Krass
                  Waoow ! Excellent !
                  Thanks for the trick (SketchUV)
                  DB
                  • 7
                  • 8
                  • 9
                  • 10
                  • 11
                  • 11 / 11
