    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    251 Posts 88 Posters 154.8k Views 88 Watching
      Loading! 😄
        Wow Chris, this is amazing. Thank you very much for this and all of your other scripts.
          Chris! That's fantastic!
          If you find yourself in Norway I'll buy you a big pint of beer!
            Click Draw
            Again.....Thanks very much. This is just amazing....great update! And if your ever in Vancouver, I'll buy you a jug of beer! 😍
            Have I mentioned how much of a laugh I get out of some of the Signatures on here!
            • JClementsJ Offline
              JClements
              Very impressive.
              Be neat if you could add in something like Joseph Lieblinger's Soap Skin method to flex the triangulated surface.
              Regards, John
                No possibility to automate the clicks of curves? 😉
                the 10 curves are made with the Grow plug by Tig
                • EscapeArtistE Offline
                  EscapeArtist
                  Fantastic plugin.
                  Thank you very much for your hard work!
                    AcesHigh
                    damn Chris, you are a genius...
                    can you please tackle the problems of cold nuclear fusion and faster than light travel, after you finish this plugin? 😄
                    just a question... what if I WANT straight lines connecting faces? You know... for something that doesnt look organic... dunno... like a ship hull or something... maybe you can add, in the final version, option for connecting with splines or lines?
                    • mitcorbM Offline
                      mitcorb
                      @Chris:
                      Thanks for another excellent effort in this Loft Tool.
                      This is to confirm proof of concept in the wild. I remodeled my guitar neck/body heel transition, and it worked very well.
                        dtrarch
                        Hi Chris
                        Heads up on alpha 0.1b
                        BugSplat on V6 latest (3 times) 😞
                        OK on V7 free latest 😄
                        Using 3 equal arcs.
                        dtr
                          sepo
                          Hmmm... I am getting Bugsplat on anything with loft tool... To be precise I draw arc (12 segments) I draw second arc (12 segments) I press loft select both arcs, hit enter choose 5 grom GUI. press OK ....bugsplat. SU7...will try now on SU6.
                            sepo
                            Interesting...it works no problem on SU6 with 2 or more arcs.
                              sepo
                              If you are refering to my case ....they had only same number of segments but not same curves.
                              • Chris FullmerC Offline
                                Bummer Sepo, your getting splats on any loft in v7?
                                Could you attach a file with shapes that splat? I'm not sure if this is a script conflict splat or if you guys are using it in ways that never crossed my mind (like with shape bender, I'm amazed at what people make that script do!).
                                So perhaps attach some example models and I'll take a look. Thanks!
                                Chris
                                EDIT: Sorry, in that previous post I was answering dtrarch - I'll edit it to make it more clear.
                                All my Plugins I've written
                                  @dtrarch - Lofting 3 equal arcs in SUv6 gives bug splats? But 2 equal arcs do not, correct? Could you post a model that splats?
                                  I'll look into it and I have a pretty good idea where in the code to start looking. I can't think of anything I've done that should splat though. Oh well, I'll try to check it out.
                                  Chris
                                  • W Offline
                                    watkins
                                    Dear Chris,
                                    I cannot seem to get your plugin to work. The loft icon appears in my toolbar, and seems to work: it changes when selected and allows the selection of the two curves (simple arcs with the same number of segments), but then nothing. I even tried exploding the arcs, but still nothing.
                                    As usual, I put the simple_loft folder and loader in my plugin folder. Is it possible that one of my other plugins is causing a problem? I have tried your plugin on two different computers (home laptop and office desktop), but with the same result. Both have the same plugins. Curious.
                                    Kind regards,
                                    Bob
                                      sepo
                                      This is console . I start loft and have this
                                      --> New Definition Added:
                                      --> 0
                                      --> nil
                                      I select arcs,press ok in GUI have this for 1 second
                                      --> 0
                                      --> nil
                                      and than bugsplat....now this happens in SU7 even with simple curves.
                                      • W Offline
                                        watkins
                                        Dear Chris,
                                        I do apolgise. I had a senior moment, or to be more precise, I failed to read your instructions to the end. Hit ENTER was the missing step. Seems to work just fine now.
                                        Kind regards,
                                        Bob
                                          Click Draw
                                          Hey Chris,
                                          Been playin' a bit...so far no probs. I'm on SU7 Pro, Vista if that helps.
                                          Jeff
                                            dtrarch
                                            Chris
                                            I checked V6 with only loft installed.
                                            It is bumping into another script or ?
                                            The same script set is on V7 and loft is OK there.??
                                            BTW the number of arcs 2-whatever still bombed.
                                            Dave
                                            • 12
                                            • 13
                                            • 2 / 13
