    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    251 Posts 88 Posters 194.1k Views 88 Watching
    • utilerU Offline
      utiler
      Will send you a few pics and video's.... 👍
      Just Curious...
      • Chris FullmerC Offline
        UPDATE! Script and video updated.
        I've now got the bezier connections from spline to spling working. What does that mean?
        Essentially the lofting actually works now. Its a huge improvement.
        You still need to make all splines have the same amount of segments though. That will be the next piece I tackle, I promise!
          video isn't loading.... Just get a white square...
            It doesn't have a loading screen?
              Sorry, its a big video. about 30mb and it takes a long time to load sometimes. So open that front page in another tab and let it load while you browse other pages.
              EDIT: Or, as it turns out, I forgot to actually upload it to my server. 😳 Try it again, thanks for the heads up!
                Oh your fast. Sorry, yeah I didn't upload it. So its uploading and should be ready now to try again.
                Thanks for pointing it out!
                EDIT: Still having issues....hold on.
                EDIT AGAIN: OK, now its working!
                  Loading! 😄
                    Wow Chris, this is amazing. Thank you very much for this and all of your other scripts.
                      Chris! That's fantastic!
                      If you find yourself in Norway I'll buy you a big pint of beer!
                        Click Draw
                        Again.....Thanks very much. This is just amazing....great update! And if your ever in Vancouver, I'll buy you a jug of beer! 😍
                        Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                        • JClementsJ Offline
                          JClements
                          Very impressive.
                          Be neat if you could add in something like Joseph Lieblinger's Soap Skin method to flex the triangulated surface.
                          Regards, John
                            No possibility to automate the clicks of curves? 😉
                            the 10 curves are made with the Grow plug by Tig
                            • EscapeArtistE Offline
                              EscapeArtist
                              Fantastic plugin.
                              Thank you very much for your hard work!
                                AcesHigh
                                damn Chris, you are a genius...
                                can you please tackle the problems of cold nuclear fusion and faster than light travel, after you finish this plugin? 😄
                                just a question... what if I WANT straight lines connecting faces? You know... for something that doesnt look organic... dunno... like a ship hull or something... maybe you can add, in the final version, option for connecting with splines or lines?
                                • mitcorbM Offline
                                  mitcorb
                                  @Chris:
                                  Thanks for another excellent effort in this Loft Tool.
                                  This is to confirm proof of concept in the wild. I remodeled my guitar neck/body heel transition, and it worked very well.
                                    dtrarch
                                    Hi Chris
                                    Heads up on alpha 0.1b
                                    BugSplat on V6 latest (3 times) 😞
                                    OK on V7 free latest 😄
                                    Using 3 equal arcs.
                                    dtr
                                      sepo
                                      Hmmm... I am getting Bugsplat on anything with loft tool... To be precise I draw arc (12 segments) I draw second arc (12 segments) I press loft select both arcs, hit enter choose 5 grom GUI. press OK ....bugsplat. SU7...will try now on SU6.
                                        sepo
                                        Interesting...it works no problem on SU6 with 2 or more arcs.
                                          sepo
                                          If you are refering to my case ....they had only same number of segments but not same curves.
                                            Bummer Sepo, your getting splats on any loft in v7?
                                            Could you attach a file with shapes that splat? I'm not sure if this is a script conflict splat or if you guys are using it in ways that never crossed my mind (like with shape bender, I'm amazed at what people make that script do!).
                                            So perhaps attach some example models and I'll take a look. Thanks!
                                            EDIT: Sorry, in that previous post I was answering dtrarch - I'll edit it to make it more clear.
                                            • 12
                                            • 13
                                            • 2 / 13
