    [Plugin] Simple Loft alpha 0.1b -- UPDATED May-15-09
    251 Posts 88 Posters 205.4k Views 88 Watching
      video isn't loading.... Just get a white square...
        It doesn't have a loading screen?
        • Chris FullmerC Offline
          Sorry, its a big video. about 30mb and it takes a long time to load sometimes. So open that front page in another tab and let it load while you browse other pages.
          EDIT: Or, as it turns out, I forgot to actually upload it to my server. 😳 Try it again, thanks for the heads up!
            Oh your fast. Sorry, yeah I didn't upload it. So its uploading and should be ready now to try again.
            Thanks for pointing it out!
            EDIT: Still having issues....hold on.
            EDIT AGAIN: OK, now its working!
              Loading! 😄
                Wow Chris, this is amazing. Thank you very much for this and all of your other scripts.
                  Chris! That's fantastic!
                  If you find yourself in Norway I'll buy you a big pint of beer!
                    Click Draw
                    Again.....Thanks very much. This is just amazing....great update! And if your ever in Vancouver, I'll buy you a jug of beer! 😍
                    Have I mentioned how much of a laugh I get out of some of the Signatures on here!
                    • JClementsJ Offline
                      JClements
                      Very impressive.
                      Be neat if you could add in something like Joseph Lieblinger's Soap Skin method to flex the triangulated surface.
                      Regards, John
                        No possibility to automate the clicks of curves? 😉
                        the 10 curves are made with the Grow plug by Tig
                        • EscapeArtistE Offline
                          EscapeArtist
                          Fantastic plugin.
                          Thank you very much for your hard work!
                            AcesHigh
                            damn Chris, you are a genius...
                            can you please tackle the problems of cold nuclear fusion and faster than light travel, after you finish this plugin? 😄
                            just a question... what if I WANT straight lines connecting faces? You know... for something that doesnt look organic... dunno... like a ship hull or something... maybe you can add, in the final version, option for connecting with splines or lines?
                            • mitcorbM Offline
                              mitcorb
                              @Chris:
                              Thanks for another excellent effort in this Loft Tool.
                              This is to confirm proof of concept in the wild. I remodeled my guitar neck/body heel transition, and it worked very well.
                                dtrarch
                                Hi Chris
                                Heads up on alpha 0.1b
                                BugSplat on V6 latest (3 times) 😞
                                OK on V7 free latest 😄
                                Using 3 equal arcs.
                                dtr
                                  sepo
                                  Hmmm... I am getting Bugsplat on anything with loft tool... To be precise I draw arc (12 segments) I draw second arc (12 segments) I press loft select both arcs, hit enter choose 5 grom GUI. press OK ....bugsplat. SU7...will try now on SU6.
                                    sepo
                                    Interesting...it works no problem on SU6 with 2 or more arcs.
                                      sepo
                                      If you are refering to my case ....they had only same number of segments but not same curves.
                                        Bummer Sepo, your getting splats on any loft in v7?
                                        Could you attach a file with shapes that splat? I'm not sure if this is a script conflict splat or if you guys are using it in ways that never crossed my mind (like with shape bender, I'm amazed at what people make that script do!).
                                        So perhaps attach some example models and I'll take a look. Thanks!
                                        EDIT: Sorry, in that previous post I was answering dtrarch - I'll edit it to make it more clear.
                                          @dtrarch - Lofting 3 equal arcs in SUv6 gives bug splats? But 2 equal arcs do not, correct? Could you post a model that splats?
                                          I'll look into it and I have a pretty good idea where in the code to start looking. I can't think of anything I've done that should splat though. Oh well, I'll try to check it out.
                                          • W Offline
                                            watkins
                                            Dear Chris,
                                            I cannot seem to get your plugin to work. The loft icon appears in my toolbar, and seems to work: it changes when selected and allows the selection of the two curves (simple arcs with the same number of segments), but then nothing. I even tried exploding the arcs, but still nothing.
                                            As usual, I put the simple_loft folder and loader in my plugin folder. Is it possible that one of my other plugins is causing a problem? I have tried your plugin on two different computers (home laptop and office desktop), but with the same result. Both have the same plugins. Curious.
                                            Kind regards,
                                            Bob
                                            • 12
                                            • 13
                                            • 2 / 13
